Volks AutosEM Tuning
Results 1 to 34 of 34
Like Tree1Likes
  • 1 Post By quattrojames
Thread: DEFROSTER FLAPS STUCK SHUT
    CEC
    Exhausted
    Dec 2010
    Clitheroe, Lancashire
    Has anybody got a cheap fix please?
    Got up this morning to a frozen windscreen so started car to warm things up only to find after 10 mins the screen was still full of frost.
    It seems that the flaps are stuck shut!
    Got the following fault codes
    00710
    00716
    01809
    01810
    01842
    00716
    don't know were to start with this lot so any help would be good
    Thank's.
    ps I know that the code 00710 ref to the defroster motor but not sure which one this is on the side of the heater box?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    CEC
    Exhausted
    Dec 2010
    Job done,thanks for the link James.
    A little confused as to why the red lever keeps moving even when ignition is switched off,this must be the noise I have had for a while! is this normal ?
    Mar 2008
    Dorset
    13,856
    I think so, I'm not sure but I think it might be down to the release of air pressure in the system as it settles.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    a also have heater servo gremlins for a minute or 2 after i take my key out
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Oct 2009
    Hull
    1,442
    Quote Originally Posted by marktdisport View Post
    same here
    and used to suffer with the stuck flap too so i removed the motor and left the flap open far cheaper then a motor lol ......temp fix till funds allow etc
    Jan 2011
    687
    Me too, should I be worried ?
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Jul 2011
    mids
    1,193
    hope not !!! i aint lol.....hey stu when you say you removed motor have you unplugged it or just removed linkage and manually opened the flap up etc... i'll be doing this friday m8 thanks
    A4 TDI 130 SPORT..
    Oct 2009
    Hull
    1,442
    i just removed the motor and left it hanging there mine doesnt do a lot so left it plugged in left it on the linkage to let the weight keep it open
    Jul 2011
    mids
    1,193
    Thumbs up
    thanks stu will do this today...
    A4 TDI 130 SPORT..
    Jul 2011
    mids
    1,193
    done and now working just need some new servos for full repair..... i got 2 motors with heater gremlins aswell as vthe red linkage one is having a fit when ignition switched off
    A4 TDI 130 SPORT..
    Oct 2009
    Hull
    1,442
    i saw a full heater system on ebay the other day for £110 was the full unit with all servos and fan it had the b motor too which is the updated? one
    Jul 2011
    mids
    1,193
    damm thats cheap they want nearly that for the green linkage servo
    A4 TDI 130 SPORT..
    Oct 2009
    Hull
    1,442
    yes i know i was going to buy it but funds are low!!
    Nov 2011
    Hi Guys. Have just had the same problem on my car. Don't rush out buying the motors. I stripped my motor apart (the top one code v710 defrost flap) (carefully) and found the grease inside wasn't lubricating the mechanisum. Taking the motor out filling with a fresh very light weight grease exercised the gears put back together and hey presto all working.So carried on down and did all the others including the recycle flap motor. They retail from audi for around £104 each fo my B7. The red linkage is the temperature control flap which keeps twitching especially on digital climate to maintain temp then creaps round to cold when switched off to help reduce huffing up when parked.
    Oct 2009
    Hull
    1,442
    how long ago did you do this?
    if only a few days let us know how you get on after a month if all is well i think i wll do the same
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by Dellorto Esteven View Post
    I had wondered about stripping mine down, but decided to wait until it was fubar rather than just intermittent, I had assumed being intermittent it was an electrical rather than mechanical fault.
    As mentioned it will be interesting if it holds out, normally when I manually move the mechanism on my demist flap it works again for a while.
    Fancy doing a run through with some pics?
    Jul 2011
    mids
    1,193
    great stuff lets hope it works well in a month
    A4 TDI 130 SPORT..
    Nov 2011
    Yes it has only been about a week so far but i will let you know soon, as the cold starts creeping in there reliabilty will soon show..
    As for the task its very straight forward. Once the the unit housing is opened all that's inside is a small motor much like one from a radio controlled car.This winds a plastic spindle/worm gear rotating the large gear holding the arm that moves the flap. On the reverse of this their is a very basic rehostat that just just signals the motor when and how far to run in order to open,close the flap partially or fully.
    How to do the task .....
    The case simply clips together with 6 little claw clips you'll need something thin and pointy for this part.
    Once open remove the motor and rotate its shaft to insure the motors ok then liberally apply grease to the spindle where it engages with the large gear and using your finger nail rotate the spindle at the bottom from where the motor engages it to ensure the lubricant gets fully into the teeth on all the plastic parts and that the green arm on the outside moves through its full range, then wind it back to the start. Refit the motor greasing its little gear. Then remove rehostat and make sure the center rotates freely and refit I lubricated this part too. Clip on the cover and your all sorted.
    I used a light weight spray grease on mine from wurth. It its green in colour and called an open gear grease very good and you can spray all the swivel points on the air box. Its very low tack so won't then collect dust and clog up. Vasaline is probably the next best thing.
    As with all plastic things i would suggest getting it some where warm for a bit to make the case a bit more flexible for opening.
    You'll wonder why its so expensive once you've seen inside and i'd probably be more inclined too play with them when there intermittant so as to save the motor from undue stress.
    I wish i'd thought of taking some pics now whist it was all apart to make the explanation easier. doh
    Hopefully this helps enough for now.
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    I have definitely got dodgy flaps in my car, and the gremlin noises after the key has been removed too. I think i'll take a look at this over christmas, and see what I can find.
    Thanks for the write up
    Nov 2011
    Hi Guys . Thought i should check in and give you an update on the flap motor strip and regrease.
    Nearly 2 months on and their working like new. This is a daily use car and with the cold weather they are definately being put through their paces.
    Perhaps more people can follow suit and save filling up waste bins with these little but expensive motors.
    Mar 2008
    Dorset
    13,856
    Thanks for the update, several people have had this problem of late!
    Jan 2012
    Thanks for suggesting the cheap fix of removing the motor and leaving it hanging. Did that last night before a long run today and seems to keep the screen clear! Any ideas on how to get the green linkage off the motor spindle so that I can try and fix it properly at the weekend (thanks Dellorto Esteven for instructions)?
    Jul 2011
    mids
    1,193
    just spin the motor round on the shaft/linkage bud and then the little slot lines up and slide it out
    A4 TDI 130 SPORT..
    Jul 2011
    26
    Hi all, I also had/have the same problem with my a4 convertible .... It's with the green servo motor, I bought a second hand one on eBay befor I knew about the cheap fix mentioned above, problem I still have is that once fitted still it doesn't work... I had all the same noises as the rest of you guys before it stopped working, eventually I tried the cheap fix and put back to gather still it will not work, I read I should use the plug and play clip from another servo motor beside the green one and see what happens and hey presto... It works ( both them) now I am lost completely !! When I plug and reconnect the green servo nothing is happening, can't see any wires broken or sliced, checked all fuses and fine????? Please help if you have had a similar problem.... The only other thing I can do is disconnect and leave hot air coming through the flap?? Thanks
    Jul 2011
    26
    Hi again, anyone got any suggestions on what to try next thanks
  28. #27
    Jul 2011
    26
    Help anyone.... Not sure what to try next to get the motor working on the green linkage arm, suggestions please.....
  29. #28
    Mar 2008
    Dorset
    13,856
    Have you power at the plug?
  30. #29
    Jul 2011
    26
    Hi there, yes I believe there is power at the plug as when I plug in the servo it makes a very slow repositioning of itself.... This is only when plugged in but not linked up to the green linkage arm that controls the flap. I'm at a loss as not sure where to begin ??? When linked up basically nothing happens?? Any other suggestions?
    Please??
  31. #30
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    and is that with the old or new motor or both?
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
  32. #31
    Mar 2008
    Dorset
    13,856
    I can't fully understand what you're saying to be honest. It's possible the climate control system is knackered. I know it's a cliche, but it's worth getting the codes scanned to see what error codes are there rather us trying to second guess the problem.
    Watchthisspace123 likes this.
  33. #32
    kite's Avatar
    Oct 2007
    East Berks
    675
    You could try running the motor through "basically settings" with vagcom
    A4 (b6) 2.5 TDi QS Saloon.
  34. #33
    Jul 2011
    26
    Quote Originally Posted by kite View Post
    Thanks guys, I don't have a vag-com....but will get into a Gaurage .... Think it must be electrical, sorry if I wasn't clear, basically the servo motor works when plugged into the red linkage plug and play( both motors) but nothing when all plugged in and connected to green linkage.... Must be a fault code attached???? But thanks guys.... Any other suggestions welcome!!
  35. #34
    Oct 2009
    Hull
    1,442
    do you mean no motor moves the green linkage? could be seized up somewhere
  1. Mud Flaps
    By jon-easy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th January 2011, 09:43
  2. Mud flaps
    By gingers3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th October 2009, 12:21
  3. Front windows stuck shut - Intermittent
    By 3.2 Ju in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2007, 07:26
  4. Flaps?
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2006, 21:26
  5. flaps ???
    By myzeneye in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2005, 17:21
