Monster MotorsportChris Nott
Results 1 to 8 of 8
    Jan 2011
    612
    Cold air on drivers side only....
    Hi guys,
    Have a weird one for you, earlier this year I fitted a B7 climate control unit and about 8 weeks ago I started getting cold air only on the drivers side of the car, it was diagnosed as a heater flap motor and last weekend I managed to find a B7 in a local breakers and removed ALL of the heater flap motors and fitted them to my car.
    My independent then coded and adapted all the motors, but I am still getting ice cold air through the drivers side of the car......
    Could this be anything else? control unit/temp sensors anywhere? Could I have fitted the levers incorrectly to the motor??
    Cheers in advance
    Steve
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    Jan 2011
    687
    Did you set the flap positions and power up the motors before connecting the links ? Flap could be misaligned.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Feb 2006
    Lincolnshire
    721
    Well, if you've changed all the flap motors, and the original problem persists, then my logic would say that the climate control unit is the likely culprit?
    How was the flap motor fault diagnosed?
    All the flaps are controlled by the CCU as far as I know, so that's where I'd be looking.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Jan 2011
    612
    Cheers guys,
    Motor was diagnosed by my independent (ex audi master tech) who has full diagnostics available, in terms of setting up, I replaced the motors, connected the levers and then all the adaptation was done by my independent, so I would imagine that the flap positions were set correctly...
    No faults showing with CCU, so that's why I was wondering if there was maybe a temp sensor for each side of the car and that is what has gone faulty....
    I'll be peeved if it's the CCU though, it came out of a B7 with 40K on the clock 6 months ago.......
    Jan 2011
    687
    Climate units pop up on eBay all the time, I got one listed myself at the moment,
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,016
    my friend had the same issue with skoda, turned out to be low ac gas.regas sorted it out fine.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jan 2011
    612
    It's not low gas, had a full aircon service done this year, no leaks and also replaced the high pressure switch at the same time as this was flagged up.....
    I think I'll remove the drivers side flap motor and make sure the levers are in the right position tomorrow, and also try refitting my old CCU unit which I still have and see what happens.....
    Jan 2011
    612
    typical.....
    took out ccu that I fitted 6 months ago from a 40k B7 model and fitted my old 100k B6 unit and now everything works perfectly.......
    Now need to find another B7 unit as I did the wiring harness upgrade with a relay in place to make sure heated screen works......
    grrrrrrrrrrrrrrrrrrrrr
  1. Removing the drivers side air vent...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th June 2012, 03:34
  2. Drivers side headlight lower than passenger side (S3 Xenons)
    By devan in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2010, 14:31
  3. Blowing hot on pasenger side, can't adjust, ok drivers side.
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2009, 13:54
  4. S3: (FMIC piping) Why 2" on hot side and 2.5" on cold side
    By Dennis Moeller in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2009, 01:53
  5. Replies: 4
    Last Post: 1st September 2006, 09:16
