AH FabricationsChris Nott
Results 1 to 7 of 7
    Apr 2010
    27
    Windows Open in Morning
    This morning, I went out to the car and both front windows were down about an inch or 2. Car was locked and nothing amiss.
    Had a quick Google and search around the forums and it seems to be pointing towards having inadvertently pressed the unlock button a few seconds, which lowers the windows. Probably whilst fob and bunch of keys were in my pocket.
    Tested the fob and "windows down with remote" is on. Will be removing that tonight with VCDS.
    Just as a long shot - does anyone know if something similar would happen with the car battery was on it's way out? It was cold last night and I've had the cold weather help a weak battery die, before.
    Dibs
    p.s. It's a '53 B6 130 Avant.
    Jul 2007
    770
    I think its only the fob and its safest to remove if its happened.But car shoulld not have unlocked or locked itself if door had not been opened
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    like he said car was locked
    so if he pressed button by mistake in pocket it would lower windows and relock its self
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I'm sure thats what happened, I've done it once and panicked a bit when I discovered it! Touch wood, it's not happened since.
    Lancaster
    1,788
    Seeing as my fob works from around 3 miles away. I thought it was a good idea to disable them going down with vagcom.
    To do: None yet.
    Apr 2010
    27
    Thanks for the replies chaps. I haven't programmed it out this evening - just making sure the fob can't accidentally get pressed and ifall is well overnight - will program it put tomorrow.
    Dibs
    Jul 2007
    770
    My thought was if the car will self lock if the door not opened why does it not shut the windows too?
  1. Windows all open by about 2"'s on my Audi A4 AVant Sline
    By marballs in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th June 2011, 12:24
  2. Replies: 2
    Last Post: 13th May 2011, 01:55
  3. All Windows open/closed
    By pcmanning in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2009, 10:42
  4. open and closure of the windows with key fob-S3
    By stressfrees3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 13:44
  5. windows found open? very strange!
    By cnpaterson in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2005, 15:20
