AH FabricationsEM Tuning
Results 1 to 14 of 14
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    New thermostat fitted... Is it failing again?
    Drove home this afternoon, and noticed my temperature gauge only got up to 1/4 hot on display.
    I changed the sensor a few weeks ago only to find out it made no difference, so booked it into Awesome for thermostatt fitting, all as been well for the last week or so till I drove home today.
    Is it possible the new thermostat is faulty?
    Rung Awesome up, said I will have to pay if it's not thermostat ( fair enough ). worried now I'll be folking out again.
    Anyone had a new TS fail?
    Thanks.
    2003 - Akoya silver A4 1.9 tdi (100) Sport
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,258
    its always possible for a new part to fail, hows the waterpump? old/new
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Quote Originally Posted by swarcup View Post
    Had cambelt and water pump done last month.
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Quote Originally Posted by macpdm View Post
    Sorry don't understand what I'm supposed to do watching the films?
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    By setting up the climatronic to show engine temp you can then look at the dial on your dash and if they are reading about the same then you know your temp sender is working correctly.
    I think
    Just found this which may help further I hope
    VWVortex.com - Climatronic diagnostic codes
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    I think
    Well I drove to work this morning and the gauge hardly moved, when I got to work I left the car running and set the climate control to the lowest temp I could using the trick in the video ie: 64 degree. Now the gauge needle moved slowly up to about 64 degrees on the display ( gauge) no more, but the temp display on the climate control didn't move from 64 degrees.
    Does this then point to the thermostat.?
    TIA
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    I bet your Temp sender has FAILED
    AUDI A4 190T S-LINE.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    thats not showing engine temp
    just how to switch between c and f
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Quote Originally Posted by CMD View Post
    I bloody hope not! I've got it booked into the garage tommorow saying they've fit me a faulty TS. How can I find out for certain what it is? I can't afford another £90 again if it's not the TS.
    And would I be able to get my money back from VW for the Temp Sender if it turns out to be that?
    Starting to get fed up with this car now, starting to cost to much money.
    Thanks.
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Buy your temp sender from TPS or GSF
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    It was a OEM sender should of been good.
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Took the car back to the garage today to get a new thermo fitted after I told them the one they had fitted was faulty. Guy put it on the vagcom and after 30 mins said the problem was not the thermostat, he checked the gauge out put and watched gauge and measuring blocks ( science I don't understand ) anyway after paying £33 for them to check it and telling me it was all good I drove home.
    Turned back round after it wasn't right, and demanded they fit a new thermo, still said he didn't think it was the thermo so I said I would get it fitted somewhere elseand they could reimburse for all money lost if it was the thermo.
    1hr later agreeded to fit me a new one and all was good again, said they had fitted me an uprated thermo no extra charge, and apologised saying they have never had a faulty one before. Got my £33 refunded for the vagcom and off I went.
    Thanks to this forum I told them I was adamant it was the tempo after the advice and symptoms mentioned on this forum.
    Sorry it's a bit long winded but just shows new tempo's can be faulty.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Well done fella glad you got it sorted.
  1. I take it I need a thermostat fitted.
    By Jason-Con in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd January 2010, 11:11
  2. Headlight Keeps Failing
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd November 2009, 21:29
  3. Second DV failing?
    By A3ster in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2009, 10:49
  4. Crank sensor failing ?
    By MattS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2006, 16:57
  5. Fuel pump failing
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2005, 09:23
