Sky InsuranceJMB Retrofits
Results 1 to 7 of 7
    Apr 2010
    Burnley, near monty carlo !!!
    351
    After a part number + Advice PLEASE!!!!!!
    Hi all, i know this has been covered before but need some advice and info.
    For sometime now my cars temp gauge doesn't seem to work that well, looking @ the gauge 50 is cold 70 is quarter and 90 is half.
    My car warms up ok the gauge prob goes upto 75/80 then drops back down to a quarter or just under, if i leave it ticking over and not moving for a bit the gauge goes up again.
    I know that the temp sensors can play up, is it worth replacing the sensors? + does anybody have the relevent part number?
    Is there something other than the temp sensor that could be causing it?
    My cars losing water @ the rate of a pint in about 4 weeks or 900 miles ish, so just trying to get the temp sensor right incase my water usage gets worse, im hoping its either a split pipe or the water pump, and im praying and praying its not the head gasket.
    Any help would be great.............thanks all...
    A4 TDI SPORT with full leather and thats it as standard.Fitted by me.Remap,S-LINE BADGES.S4 Wing mirrors.DIS,Seat Cupra splitter.Rear parking sensors.5k hids+LED side lights+DRL lights+chrome indicator bulbs,amber fog lights.LED Xenon number plate bulbs,upper/lower front grills+boot strip in matt black.Ipod dock.19" BMW X5 SPORT CONCAVE ALLOYS,9 J FRONT 10 J REAR 20mm hub adapters front ET 28,18mm hub adapters rear ET 27.
    TO DO.B5 spring perches.Renault rear diffuser?? S/S exhaust.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,257
    sounds like there is a problem with iether the thermostat or water pump, i would say thermostat but if your losing water then possible water pump, have you looked to see where the water is leaking?
    Apr 2010
    351
    Quote Originally Posted by swarcup View Post
    Im taking it upto my dads garage this weekend to try and find the leak, how much are water pumps?
    Is it worth replacing the thermostat anyway?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    its the stat
    Apr 2010
    351
    Are the thermostats easy to replace, you dont need to hook them upto a vag-com after do you??????
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,257
    no its a bolt off and bolt on part, around fifteen quid from audi. Only shop at audi for these aswell. Location is around the rear of the engine i believe if its a 1.9tdi? just guessing from your remap figure. oh and get yourself some g12 antifreeze to top up as you will lose a bit when you take the old off and new on.
    Apr 2010
    351
    Cheers i'll get one ordered, Do i need G12 antifreeze??? i've just brought some normal red antifreeze which is meant for most engines and works down to -37 degrees.............can Audis only use certain antifreezes??
    I've found the water pump price using that spot on Audi parts finder in the sticky thread, euro car parts are coming out @ about £42.00 but wierdly it lists four different pumps, two of each make and all slightly different prices.....
    Im gunna have a hunt in the parts sticky again and see if i can find the part number for the thermostat....
  1. Part Number, or part from a breaker needed
    By Arrkon in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th April 2011, 19:39
  2. Part number check on chassis number
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2010, 09:01
  3. new turbo, remap advice and part number
    By ian 06 A3 2.0 tdi s line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th September 2010, 19:24
  4. Part number advice
    By CocnutMacaroon in forum In-Car Entertainment
    Last Post: 31st December 2008, 16:28
  5. Help / Advice needed with part number
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2006, 23:16
