Monster MotorsportEM Tuning
    boya's Avatar
    Aug 2009
    consett county durham
    394
    2.5 tdi, coolant change
    Does the system need bleeding? I am in the process of changing a pipe and most of the coolant has gone, I will be taking the bottom radiator hose off to make sure it's all out before I put fresh in, now is there a procedure to follow when re-filling the coolant system? Cheers.
    Jul 2007
    765
    Saw this done wnen the belts were changed and I think that you hold the tank up high as poss to let the air escape and no bleeding needed
    Jul 2007
    London
    3,074
    You need to expose the bleed hole on the heater matrix pipes on the bulkhead...whilst the engine is running with the cap on, you will get a little stream of water from the hole then you know its bleed ! caution as is hot so use a cloth to avoid scalding !
    FOR SALE:
    boya's Avatar
    Aug 2009
    394
    Sweet, cheers for that mate
    boya's Avatar
    Aug 2009
    394
    How do you get access to the bleed nipple on the heater matrix pipe?? It's not down the back of the engine so am I right in saying its where the battery etc is??
  1. coolant flush/change
    By mrjheeta in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2011, 14:19
  2. A6 2.5 TDi coolant change..........
    By Nessy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th April 2009, 10:54
  3. COOLANT problem 2.0 tdi
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2008, 16:51
  4. 2.0 TDI Using WATER (COOLANT)
    By stevehsv868 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th October 2007, 19:11
  5. Coolant change
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2006, 18:17
