Volks AutosChris Nott
Results 1 to 13 of 13
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    squealing power steering
    This is one that's been going on for ages but I haven't worked it out. when my steering is at full lock I get squealing from some part of my PS system. I thought i'd cracked it when I changed my v belt tensioner and belt during the summer but it's still the same. it's worst when i've just started up from cold, suggesting the pump itself or belt are less forgiving when cold. At times I get a bit of squeal just turning half way, not even on full lock. that does tend to be when the car is cold though.
    any ideas anyone? And no, it's not a cat stuck in my undertray
    cheers
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    When you say 'cold', are you talking Finnish winter cold? Might just be cos the belts stiff then?
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    no mate, could be 20 degrees and it will still squeal when on full lock
    Lancaster
    1,785
    Could be the alternator clutch pulley
    To do: None yet.
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    thanks mate. Is that a typical offender for this kind of noise? if/when I get etka 7.3 working i'll look the part number up and see if I can get access to it without removing the whole sodding front end.
    May 2011
    136
    Mine also does this , just mine seems to be when on full lock whatever the temp !
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    sometimes, low power steering fluid is to blame,
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    i'll double check the fluid but i'm pretty sure it's ok (famous last words )
    May 2011
    136
    When I bought the car (privately) the brake system warning light kept coming on , discovered the power steering reservoir was empty ! Filled it up and left the cap off and turned from lock to lock for a few minutes ! The squealing is still there but not quite as loud !!
    190 S LINE QUATTRO
    somerset
    81
    Does the serpentine belt flap around a lot when the engine is idling, this gives the impression that the tensioner is weak, but in most cases is due to the one way clutch in the alternator pulley.
    I replaced my pulley in august because the belt was moving around so much it was causing the tensioner to rumble when pulling away on low revs, new pulley from TPS (genuine audi) was £80, took an hour or so to fit as the alternator needs to come out and you need a special tool to remove the old (and very tight) pulley, new one in and as good as new. You can check the pulley by removing the belt tension, gripping the pulley in your hand and quickly jerk it clockwise and counter clockwise, it should grip one way and slip the other way, its not a free running slip, but you should get a fraction of a revolution out of the alternator.
    Z82
    Apr 2006
    Inverness, Scotland.
    453
    Mines been doing this recently but mine is only on full lock to right :-/
    7. 2003 B6 Nogaro Blue S4 v8 quattro
    Gone but not forgotten:
    6. 1996 B5 Casablanca White A4 2.6 v6 quattro Sport
    5. 1989 B3 Maroon Coupe 2.0E
    4. 1986 B2 Red Coupe 2.2E Limited Edition
    3. 1985 B2 Red 80 Sport
    2. 1983 B2 Black 80 Sport
    1. 1984 B2 Silver 80 Sport
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    I haven't noticed that about the belt flapping but then I haven't really been looking for that. I'll check today. Even if it's not flapping in an obvious way it sounds likely that it could be to blame. 80 quid... I hope that's it and it won't turn out to be one of those cases where I change everything in sight and turns out to be something silly
    beachbuggy's Avatar
    Surrey
    1,745
    Squeaks in the pas will be air in the system. Best course of action is to drain the pas. Replace the fluid and then jack the front of the car up until both wheels off the ground. Then bleed the system by turning the steering wheel onto full lock both ways until the sound has gone. May take a while but will work.
  1. Power steering fluid leak - anyone used Lucas power steering fluid leak stop?
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2011, 19:27
  2. Power Steering and Steering Lock
    By S3Sport_Guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2010, 21:20
  3. power steering
    By djb83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2010, 18:40
  4. Power Steering Help...
    By Julian978 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2009, 12:45
  5. Power steering
    By melcon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2008, 13:32
