Monster MotorsportVolks Autos
    Aug 2008
    Leeds
    152
    Question What is the Standard Brake Fluid in a 2003 A4 B6 1.9 TDi?
    Hi there,
    Just a quickie - is the standard brake fluid in my 2003 Audi A4 B6 1.9 TDi DOT4 fluid or is it DOT4.1?
    I need to top up the fluid a little and I have some DOT5.1 at home.. would putting some of that in on top of the existing fluid cause a problem? In other words, will it just mix and be ok or will it react and cause a problem?
    If I do need to get some new fluid, do I need a certain brand or cert spec fluid?
    Cheers,
    J
    gavsman's Avatar
    Sep 2011
    379
    Haynes manual I have say's DOT4
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Should tell you on either the cap or on top of the reservour
    Aug 2008
    Leeds
    152
    Nice one, thanks!
    J
  1. stupid clutch and brake fluid question..do i use the same fluid?
    By Rob_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2011, 10:19
  2. Just bled the brake fluid and replaced...Brake warning lights!!
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th December 2010, 01:05
  3. Brake fluid?
    By MAD HATTER in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2010, 21:28
  4. Braded brake line and brake fluid help.
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2010, 08:23
  5. Brake fluid change. 1.9 tdi
    By BlackQuat in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2010, 18:04
