AH FabricationsSky Insurance
Results 1 to 15 of 15
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    H&R lowering springs on B6 1.9TDI on original dampers.
    Starting to get the modding bug.... Would it be ok to fit H&R lowering springs on my B6 with the original damper's?
    The car as done 119,000 miles mostly motorway miles.
    It is A4 b6 1.9TDI 100 sport.
    Thanks.
    2003 - Akoya silver A4 1.9 tdi (100) Sport
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    It will be 'ok'. In an ideal world it would be better to swap the shocks too, especially if you're paying someone to do it as the labour cost will be the same. But if finances prevent that then you'll be ok, it might just reduce the life of your exisiting shocks a bit, and they won't work with the new springs quite so well.
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Yeah I know what you saying, but yes finances are a bit tight at the moment, would just like the low look the cheapest way possible.
    Thanks.
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Save until next year (spring) and then get the shocks & spring's done then
    AUDI A4 190T S-LINE.
    Mar 2008
    Dorset
    13,712
    Quote Originally Posted by gkf9 View Post
    Thanks.
    I know what you're saying, I put springs on mine a few weeks ago and kept the shocks and it's fine.
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Quote Originally Posted by CMD View Post
    Yeah would like to do that, but I'm not the best saver and would probably end up buying something else and not get round to the suspension at all.
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    How much am I likely to pay for fitting? Please don't say fit them yourself I haven't got the tools nor the confidence. Plus might not go down to well with the wife spending money on car.
    Mar 2008
    Dorset
    13,712
    Ballpark of somewhere between £100-200..
    Mar 2008
    1,017
    i put h and r on my cab with standard shocks all is fine .. the handling is awesome and a very good ride not hard at all .. if you do it your self watch out the the dreaded bolt .... i didnt undo it i took of the hub nut the the break discs and undid the lower ball joints and took it off that way much easyier then trying to undo the bolt and only took 3 hours to do all 4 springs . back ones are so dam easy long as you got the right spring clamps
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Would I have to have all the geometry set up if I put lowering springs on?
    Again thanks.
    Mar 2008
    Dorset
    13,712
    I didn't no. No real need to as I don;t think any of the parts you undo are adjustable.
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Ok thanks James.
    Got a price off Awesome £408 fitted, did say these were the most expensive ones tho.
    Just been looking at my car, and it is quite low already ( more so at the rear ) just hope the springs won't make it to low if I go ahead?
    Mar 2008
    Dorset
    13,712
    Just be aware that the quoted suspension drops on springs are from standard SE height, a Sport is 20mm lower than that already, so a quoted 30mm drop will only give you a 10mm drop.
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Thanks for that QJ that was going to be my next question, so if I went with some 35mm drop I would be lowering it by 15mm that would be great, don't know about the rear tho, might be to low, I don't want the arc covering the wheel. I will have to have a measure tomorrow.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    With the car having 119000 miles I'd say change the shocks while your at it as they won't last much longer with lowering springs.
    You also always need to get the alignment checked after fitting any suspension part and especially one that lowers the car.
    Sometimes doing things the cheaper way to start with end up costing more in the long run.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
  1. Replies: 58
    Last Post: 30th August 2011, 20:50
  2. Audi A4 Weitec Lowering Springs and Dampers
    By mrjheeta in forum For Sale/Wanted - Audi Parts
    Last Post: 20th June 2011, 15:41
  3. S3 40mm springs & dampers
    By sturs4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2011, 16:38
  4. recommended lowering springs/dampers
    By audivro in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th May 2008, 21:57
  5. Bilstein dampers and H&R springs
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2004, 10:02
