Volks AutosBadger5
    Oct 2006
    48
    headlight adjustment help.
    on the top of each headlight is two adjustment screws, is one for up and down and is one for left and right, if so which one is which. cheers.
    Sep 2010
    167
    If you haven't already done this, from memory the left headlamp should be the left screw and the right headlamp should be the right screw, the screw thats nearest the dipped beam bulb, this is standing at the front of the engine.
    Oct 2006
    48
    so are you saying that as you stand in front of the car the outside adjusters are the up and down and the inside ones are for left and right.
    Sep 2010
    167
    Yes i believe so, why do you ask anyways? do you want to adjust them for mot? , if so you are prob better getting a station with a light tester to do it to get it exactly where it needs to be
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Park against a wall with the lights on, and see which adjuster does what.
    As mentioned though, you'll never get them right without a beam reader.
  1. headlight adjustment
    By mark.colledge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2010, 22:13
  2. S3 headlight adjustment help
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2010, 13:27
  3. s3 headlight adjustment???
    By S3-Chris in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th October 2008, 21:51
  4. headlight adjustment up and down
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 22:00
  5. Headlight adjustment
    By kgough in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th July 2004, 20:03
