If you haven't already done this, from memory the left headlamp should be the left screw and the right headlamp should be the right screw, the screw thats nearest the dipped beam bulb, this is standing at the front of the engine.
Yes i believe so, why do you ask anyways? do you want to adjust them for mot? , if so you are prob better getting a station with a light tester to do it to get it exactly where it needs to be
