Badger5AH Fabrications
    Oct 2011
    Audi A4 Cabriolet 2003 Diesel 2.5 TDi V6
    Hi All
    Hope someone can help with this one.
    I have a problem when driving the car normal in the sense that when I take my foot off the pedal the rev counter drops to tickover.
    Not all the time but when it starts to do it it seems to carry on for a long time.
    I have fault codes as follows.
    01315
    18055
    18265
    18033
    They all seem to relate to the following.
    Malfunction Indicator Light (MIL) ON or Active
    Engine control unit / Transmission.
    Any Ideas on a fix or more info would be a great help.
    Thank You
    Katy
    Oct 2011
    Hi All
    Update on my 2003 A4 Cabriolet 2.5 TDi V6
    Well slung it into the specialists at Audi. Tonbridge Kent Uk
    They took car for a spin with me and as normal for the start wouldn't do it. TYPICAL
    However with time ticking on the money pot and frustration the Audi Tech guy said lets do it again.....So we gave her some boot (That's the Car) and down the hill we came and it did it....Did what you may say well it went into free wheel in the gearbox but was still in gear.
    The Audi tech said he had never in all the time driven a car that did that. I said well my relation says at least it saves on Fuel...He laughed
    Anyway swapped places and he drove it and tried several things with the multitronic but still kept doing it and I told him it would not reset until after about 3 hours cooling down.
    YES it is heat related. It would seem that the ecu in the gearbox plays up when it gets very hot.hence all the codes as it stops communicating with everything or whatever it does.
    So New Ecu needed....Well we hope this fixes it. will update you all.
    Katy
    beachbuggy's Avatar
    Surrey
    1,744
    Sure it doesn't just need an gearbox oil change? When the oil gets warm it thins and can cause problems especially on the cvt's. Very surprised the Audi technician didn't mention this. I would personally get the oil changed 1st simply as you should do it now anyway and if it solves the problem then it's a darn sight cheaper!
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    i had a range rover that had dodgy gear changes etc when hot went on for few months then googled it to find common failure with the oil and filter in the gearbox replaced and it worked perfectly from then on...... does it have any leaks does it have any oil in the gearbox ??
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. audi avant tdi sport diesel, 2003,engine races when cold
    By darcar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2010, 19:26
