Sky InsuranceVolks Autos
Results 1 to 12 of 12
    Aug 2011
    124
    01375 fault code ??
    I have just bought a 2.5 tdi a4 on an 02, pleased with the car in general. however i have plugged in the vagcom reader to find 01375 fault code. I cleared the code went for a drive and it has since come back on
    ref ross tech:
    01375 - Valves for Engine Mounting: Stage 1
    01375 - Valves for Engine Mounting: Stage 1: Output won't Switch or Short to B+
    Possible Symptoms
    • Electro-Hydraulic Engine Mounts permanently hard
    Possible Causes
    • Valves for Engine Mounting faulty
    • Wiring/Connectors from/to Valves for Engine Mounting faulty
    Possible Solutions
    • Check Valves for Engine Mounting
    • Check Wiring/Connectors from/to Valves for Engine Mounting
    Now has anyone any more info on where this could be found on the car? any prices for the part if it needs replacing?
    Would the slight movement from the gear stick when i accelerate be caused through this part not working correctly?
    Thanks in advance
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,698
    Engine mount failure is pretty common, there are a few posts on this. Part numbers are in the Parts Sticky I think, and I'm sure Turkster started a good thread too.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    just replaced mine today. took 2 hours start to finish, didnt use an engine crane instead supported it on a jack with a spreader plate and plank of wood. Paid £105 including vat for the mount. quite an easyjob,easily diy able.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    Still a job I'm yet to do. 1 at a time is the way things are right now.
    Aug 2011
    124
    Should be covered under warranty I've only had the car 2 days and found the fault as soon as I got back
    I'll try and locate the mount and check it over, these garages are abit patronising at times as though you haven't got a clue what your on about
    Thanks for the replys though, I'll search the other threads for part numbers, just so I have an idea where will it be located? Rear middle?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,197
    there are 2 mounts one left and one right, have a look and see if any fluid is leaking from one
    Aug 2011
    124
    Cheers that will be tomorrows job then, while its on the ramp I might as well change the rear diff oil, anyone suggest the best oil to use?
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    Quote Originally Posted by swarcup View Post
    I'm going to be silly now and ask what fluid is involved with engine mounts? I take it then that they aren't just big rubber beasties like on my old s2?
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
    Turkster's Avatar
    Dec 2007
    2,713
    no, some are filled with fluid and made to harder under load.
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    aha! sounds like witchcraft to me! I wonder what the damage is for a pair on a 3.0Q? something tells me I won't have much change from 200 quid
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,197
    zilcho im guessing. gear changes are improved aswell. Mine hadnt started to leak instead it had completely sheared accross and part of the plate had done one! was knocking pretty badly
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    you just did one, the buggered one, is that right?
  1. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  2. Fault code help
    By Looney in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th May 2011, 01:10
  3. Replies: 2
    Last Post: 19th December 2010, 20:41
  4. Replies: 5
    Last Post: 18th January 2010, 23:36
  5. 2.8 Fault code help please
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th January 2009, 20:54
