I have just bought a 2.5 tdi a4 on an 02, pleased with the car in general. however i have plugged in the vagcom reader to find 01375 fault code. I cleared the code went for a drive and it has since come back on
ref ross tech:
01375 - Valves for Engine Mounting: Stage 1
[h=3] 01375 - Valves for Engine Mounting: Stage 1: Output won't Switch or Short to B+ [/h]
[h=4] Possible Symptoms [/h]
[h=4] Possible Causes [/h]
[h=4] Possible Solutions [/h]
Now has anyone any more info on where this could be found on the car? any prices for the part if it needs replacing?
Would the slight movement from the gear stick when i accelerate be caused through this part not working correctly?
Thanks in advance
ref ross tech:
- Electro-Hydraulic Engine Mounts permanently hard
- Valves for Engine Mounting faulty
- Wiring/Connectors from/to Valves for Engine Mounting faulty
- Check Valves for Engine Mounting
- Check Wiring/Connectors from/to Valves for Engine Mounting
Thanks in advance
