EM TuningMonster Motorsport
Results 1 to 11 of 11
    rob irl tdi's Avatar
    Jul 2010
    241
    Does your EGR leak on pd 130?
    Mine looks like it leaks a bit of oil. Mechanic says this is normal on the lot of them. Car still drives brillant and i always use pd oil. But am i suppose to accept that they all do it or does it need a new one or gaskets or something?
    2001 S3
    TDIPOWARRR
    Jul 2010
    618
    Mine does slightly from the 2 vent holes.
    Mar 2007
    salford gtr manchester
    556
    mine used to do that . what you will find is that in time the oil leaking from the vent holes will make its way down the black plastic arm of the anti shudder valve into the rubber diaphram that operates the arm and distroy it . when this happens you get a lot of engine shudder when you turn off the engine . audi do not sell the anti shudder valve seperately if it goes you will need to buy the whole egr valve not cheap
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    I believe blanking off the EGR will sort this out
    Jul 2010
    241
    What does the little arm do on the egr?
    2001 S3
    Jul 2010
    241
    Quote Originally Posted by yendall24 View Post
    How did you fix it?
    2001 S3
    TDIPOWARRR
    Jul 2010
    618
    My EGR is blanked off now but it still leaks slightly.
    May 2011
    225
    no idea....
    2002 B6 A4 1.9 TDi 130 Sport with fully factory Votex kit.
    Currently standard
    Mar 2007
    556
    Quote Originally Posted by rob irl tdi View Post
    when you turn the engine off a vacuum is created that pushes the arm forward closing the butterfly flap in the egr valve starving the engine of air so you get an instant shut down without any shudder
    Mar 2007
    556
    How did you fix it?
    i was lucky enough to get a new one off ebay for forty quid main dealers wanted £186.00
    Sep 2010
    stoke on trent
    37
    you still got egr fitted it will ( allard pipe )
  1. Oil leak 1.9 TDI - EGR
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2011, 14:55
  2. Do 2.0TDI BKD EGR Coolers Really Leak???
    By Tonyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2010, 13:03
  3. EGR leak
    By RyanA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th July 2009, 22:36
  4. oil leak from an EGR Valve and poor starting - related?
    By chill14 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2008, 20:10
  5. Oil Leak on TDi 130
    By Karcsi in forum Diesel forum
    Last Post: 30th January 2007, 18:35
