Sky InsuranceVolks Autos
Results 1 to 19 of 19
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Glove box damper and pin cost?
    Anyone give me an idea.
    Part no's
    Damper part no.*
    8E2880324
    8E0880802 pin.*
    2003 - Akoya silver A4 1.9 tdi (100) Sport
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Just the damper and pin, not the glovebox.
    Jul 2007
    765
    Did this a few months ago cost about£12 but check that it works OK cos the first work stiffened up so I had to take it off and get another ,This one only just works after I used WD40 onit
    alpesh26's Avatar
    Mar 2011
    264
    Quote Originally Posted by gkf9 View Post
    Part no's
    Damper part no.*
    8E2880324
    8E0880802 pin.*
    I got quoted about £19! I said no, and pinched the one out of my dads B6 before he sold it
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    T0m
    Sep 2007
    Lichfield
    452
    I put WD40 on mine and after a while it still stiffens up found putting a small hole in the top of the damper makes it work a treat!
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Quote Originally Posted by alpesh26 View Post
    £19 yeap that's a bit steep, not paying anymore than £15! Wish I had someone I could nick one off
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Quote Originally Posted by T0m View Post
    Where abouts do you put the hole?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    A silicon spray will last longer than WD40. I trimmed a small amount from the rubber ring inside the damper, this helps it slide up and down with less resistance.
    T0m
    Sep 2007
    Lichfield
    452
    The opposite end to where the little arm comes out of the damper fella!
    andywil13's Avatar
    Oct 2011
    132
    where can I buy a damper from
    If someone has bought one of these glovebox dampers, can they post where from, and how much as really want to order one.
    Jul 2007
    765
    Got mine from Audi
    Mar 2008
    Dorset
    13,712
    That would seem the logical choice....
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Just bought one 5mins ago from Audi £20
    Dec 2011
    Ipswich, Suffolk
    139
    sorry to bump this ..
    just fixed mine .. sort of .. but can the pins be bought by themselves? don't need a dampener just the pin!
    And how do i loosen off the resistance so the glovebox opens freely?
    alpesh26's Avatar
    Mar 2011
    264
    Not sure about buying the pins themselves, it broke on my dads old B6 but he just used a small nut and bolt, the oem pin is plastic and will probably break again in the future.
    have a look here to slacken the resistance of the damper Glovebox Hinge Repair
    E
    ither silicone lubricant or shave the rubber O ring inside a little bit
    Dec 2011
    Ipswich, Suffolk
    139
    Not sure what size pin and nut i need though :@ lol .. can the damper come out without removing the glovebox?
    alpesh26's Avatar
    Mar 2011
    264
    I had to take the glove box out of my b7 because the hinge snapped, so I took my damper off whilst it was all out. You should be able to remove the damper with the glove box in situ, but if not its only 5 bolts holding the glove box in (3 inside at the top and 2 underneath). Only takes 5 mins to get out and you'll need an 8mm socket.
    I used wd40 inside my damper and shaved the o ring. If you go down this route, Don't put too much wd40 inside it or it will make a weird noise when the rod moves. The noise went away after a bit though
    I'll try and have a look in the garage tomorrow if I can find what my dad used to replace the pin and let you know the sizes.
    Mar 2008
    Dorset
    13,712
    Quote Originally Posted by Daniel97 View Post
    The part number for the pin is here:
    8E0880802
    It's always worth looking in the Part Number Sticky before asking for part numbers, I've spent quite a lot of time with useful user contributions making that into a hopefully worthwhile resource.
    To ease up the damper movement have a read of this:
    A4 owners - do this today and save yourself over 150!
    Dec 2011
    Ipswich, Suffolk
    139
    Thanks James
  1. Cool Box Glove Box
    By stevehall in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th January 2010, 16:46
  2. How much is a new Glove Box
    By aaa3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2009, 21:28
  3. A4 B7 and B6 glove box
    By adcooper in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th March 2008, 20:16
  4. Glove Box Damper
    By dkelly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2007, 15:33
  5. Glove box - cool box
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th November 2006, 21:45
