Volks AutosJMB Retrofits
Results 1 to 11 of 11
    mattyboyc's Avatar
    Sep 2009
    1,222
    Headlight beam pattern
    Hi all,
    Just had a trip to my local m.o.t. place to get my beams set as the headlights have been out a few times over the summer and with winter coming and all that!!, the guy put them on the machine and the conclusion was one seemed to be set for european use and one not, although both are within the m.o.t regulation the beam patterns are different, ( one is flat and the other lifts on the outer edge) the car has had one headlight replaced after a close encounter with a deer a couple of years back, he drew a picture of the correct beam pattern, if you imagine looking at a wall with two flat lines both lifting towards the left on the outer edge. So my question is can the beam patterns be altered inside the headlight ( i.e have i moved something without realising ) or is the tester talking out of his ear!! , he did also comment on the fact that it had Hid's without washers but would not fail the mot with them as he is only interested in beam height and pattern ( light field )
    Thanks as always
    Matt
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
    Sep 2010
    167
    hi matt, yes the aims should kick up to the left, this is correct. If its kicked up to the right then this is for european markets.
    Is the straight beam on the headlamp you had replaced? , are they genuine headlamps? , prob just check the bulb is fitted 100% correctly. Im not entirely sure if a4 headlamps can be adjusted internally to alter the kick up. at present no headlamp washers with hid's is not an mot failure but with the new mot rules looming it will be a failure from what ive heard.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    From memory, xenon headlights can be adjusted for RHD by a lever, by Halogen units can't.
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    637
    I'm having trouble with my beam pattern/headlight brightness, they seem really dim... we're talking a mid-90's VW Golf level of dimness!
    Can't for the life of me figure it out what the problem is, other than both lights are 'fading' at the same time. Not bloody likely. Might just change the bulbs to be sure though.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    mattyboyc's Avatar
    Sep 2009
    1,222
    Quote Originally Posted by quattro tony View Post
    Hi, the straight pattern is not on the headlight i had replaced and yes that is a genuine one, i will remove the headlihghts again to check that the bulbs are seared correctly, i do hace a spare set of hid bulbs from a previous set that had ballast faliure so could try a different bulb.
    Thanks,
    Matt
    Sep 2010
    167
    Quote Originally Posted by benjie View Post
    Yeah might be worth changing your bulbs, One of the first things i did on my a4, Im running osram silver star, I replaced one first and then compared the two, the result spoke for themselves
    benjie's Avatar
    Oct 2009
    637
    I think I'll do that. I've always used the 'good' Halfords ones and never had problems. (I also have a friend with a trade card!)
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Halogens can be adjusted by an internal mechanical lever if fitted!
    HOWEVER - not all headlight units have them?
    Picture below from one of my headlights.
    Later Xenon headlights, maybe on A4/B7 I believe not 100%, have a VAG-COM/VCDS setting for LHD/RHD.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    mattyboyc's Avatar
    Sep 2009
    1,222
    Quote Originally Posted by Woorlord View Post
    Thanks very much for that, mine has these i have just moved the lever from up to down, see what it's like tonight,
    Thanks again,
    Matt
    Mar 2008
    Dorset
    13,856
    Do we know whether having the lever up or down relates to rhd or lhd?
    mattyboyc's Avatar
    Sep 2009
    1,222
    I would say up= uk as when I moved it down it kicked the edge up to the right, however my original headlight has the lever the one that is only 2 years old dosen't
  1. Headlight beam issues
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2009, 15:54
  2. Xenons - beam pattern
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2007, 12:43
  3. Anyone have beam pattern pics of H7 hid kit in their halogen housing?
    By DSG604 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2006, 15:12
  4. Headlight beam patterns
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2006, 19:52
  5. Headlight beam pattern and Xenons
    By cyberdude in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th May 2004, 19:09
