EM TuningAH Fabrications
Results 1 to 10 of 10
    Danb's Avatar
    Simples
    Feb 2009
    West Brom
    63
    Help Needed Guys!! Jumpstart has damaged my car?
    Hi Guys,
    Thanks for reading this. I need some help with a problem that is doing my head in a little.
    First off, I parked my car up for a week whilst I went away. My neighbor said my brake lights were on for a day or so. I have seen this happen once or twice where I come to the car in the morning and the brake lights are on, but as I drive it every day usually its been no big deal, besides, it's only happened three times in so many years.
    Anyway, the battery was totally drained, so I decided to jump start off another vehicle.
    Now my car has the airbag and ESP light coming on intermittently, it gives me warning lights for the headlight sensor and bulb failure, again intermittently, the language on the DIS has changed to german, I only have one trip function, not the two that I'm used to, and the car doesn't seem to have enough charge to turn the engine over, then after about ten turns it picks up and fires. Strange..
    I have had the car plugged into a hand held diagnostics device where it threw up loads of codes from the steering wheel slip ring (airbag??) to the control module......
    Have I fried something or reset the car to factory settings?? I really can't think of what it could be.
    The car runs OK once started so I presume the ECU is still good.
    Any help would be appreciated.
    Many thanks in advance
    Dan
    I have charged the battery but to no use, the car starts fine, but soon drains the power.
    2003 Audi A4 Avant Quattro Sport 1.8T (190) 6 Speed
    Dolphin Grey - Factory HID's - Full Colour Dis - DX Sat Nav - GmbH Bodystyling - 18" RS4 Wheels - BOSE Symphony - Black Grill Surrounds
    Planned Enhancements:- 19" BBS LMs - Eibach Springs - Koni Sports - B7 RS4 Rear ARB - A FRONT TOWING EYE COVER!
    a3tdi2001's Avatar
    437
    Blocked plenum chamber leading to water in the ECU?
    Pabs's Avatar
    Jun 2010
    Manchester
    611
    i would get it scanned using vag com you might be able to reset or clear most of your codes, if they come back straight away then unfortunately you might have damaged something
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    Danb's Avatar
    Simples
    Feb 2009
    West Brom
    63
    Thanks for the replies guys.
    I will have to check the ecu for water ingress and I will see if any codes have come back today.
    If anybody else has had or seen this sort of thing before let me know your views.
    Dan
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    I had this when the battery was disconnected for a week. my airbag module forgot the vin number of the car so threw the airbag light and the steering module forgot it as well. Had to use vagcom to relearn, change the language back to english and add the second trip function. I did have the instructions all written down on a scrap of paper but then as soon as it was all working it went in the bin. I'll have a dig around and see if I can find it all again. do you have access to vagcom?
    Also sounds like you need a new battery and a brake switch
    Sam,
    Gone
    Lancaster
    1,621
    Could be a knackered battery.
    To do: None yet.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,910
    brake switch
    maybe battery
    and get it on vcds and get the proper codes and post em up
    Jan 2011
    Aberdeenshire
    628
    Electronics do not like low voltages, they like on-off voltages. If your battery goes flat and you keep cranking until the dash lights go out, you run the risk of corrupting any of your electronic modules.
    When jump starting, leave the donor car hooked up and running for a while to give some charge to your own battery before trying to start. This gives a cushion of power, as it were, that helps prevent too big a voltage drop during the start sequence.
    It is unlikely you have damaged anything permanently. you may want to try disconnecting the battery (for at least a couple of minutes) and retrying, and if that doesn't work, then VCDS will be needed to clear all your fault codes.
    You may well then want to look into what is causing your flat battery.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Quote Originally Posted by Danb View Post
    Hi Guys,
    I had the same problem and it was the brake switch fault;cost only 11£ to the stealer and is 10minutes job to change it.
    Erase the fault codes and..that`s it!
    B6 1,9TDI AVF SPORT QUATTRO AVANT
    Mods:RNS-e sat nav,Bluetooth,Rear camera,Full led interior/exterior,Cobra PCD,S4 B5 front brakes,S line body kit+S4 door blades,S line gear knob,RS4 B7 handbrake,RS6 wheels,EGR deleted,cruise control,custom leather & alcantara seats,tinted windows,A4 B7 arms & wiper blades,BV43 turbo,FMIC,custom remap(around 200hp and 368lb/ft tourque)
    Danb's Avatar
    Simples
    Feb 2009
    West Brom
    63
    Thanks for the replies guys,
    I think i'm going to get a brake switch and a new battery and see if that works.
    I will post some fault codes on here when I get them.
    I worry i've damaged a control module of some sort.
    Any more feedback would be appreciated guys.
  1. S3 Calipers - Straight swop or Adaptors needed? Advice please guys
    By Ash B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2011, 22:21
  2. Hi guys just brought these brake discs what to you guys think....
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2010, 17:51
  3. HELP NEEDED GUYS, PLEASEE
    By lifeboatcrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th June 2010, 16:23
  4. a little help needed guys
    By degsy1967 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2010, 22:20
  5. Quick reply needed guys :)
    By Quattro_Lew in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th August 2007, 17:56
