Results 1 to 11 of 11
    Mar 2011
    suffolk
    249
    cheap brake upgrade 312mm
    hi all im from the b5 section, i have recently aquired a pair of 312mm carriers and calipers ,unfortunatly i bought them in a bit of a hurry and didnt realise they fit b6 uprights and not mine im really just after what i paid which was £100 posted) these would be ideal for any of you guys currently running either 280mm or 288mm front discs.
    make for a really nice upgrade if interested pleae just give us a pm
    cheers all
    shane
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Whats the condition , any pics
    AUDI A4 190T S-LINE.
    Mar 2011
    suffolk
    249
    they are very clean, will post pic tonight
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Sweet i can drop these on to my mk4 golf
    East Berkshire
    178
    Tangerinedream
    You should be able to use these with your current caliper.... even saves bleeding the brakes !
    I've been running this for about 7-8 years on a 1.8T quattro Sport. It came with 288mms front discs.
    Unbolted carrier, dismantle current caliper/carrier, re-assemble 312 carrier to existing caliper, fit 312 disc, bolt up 'new' carrier/caliper, insert pads.....
    Not as good as a proper 'big brake' kit but a worthwhile small improvement imho
    ChrisG
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    kingfisher: he has mk5 golf calipers, which use a wider spacing to what the B5 uses, hence why he cant just do what you've said!
    B5 uprights only work with Mk4 golf/Mk1 TT/8L S3 carriers.
    TD5 Land Rover Defender build
    East Berkshire
    178
    Ah ! Sorry Tangerinedream --forget what I said then !!
    CMD looks like its GO !
    ChrisG
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Yep the 312 setup is what all the MK4 lot are doing
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    if CMD changes his mind im going to be taking the b5 321mm set up of my A4 B6 (swap?)
    gavsman's Avatar
    Sep 2011
    379
    Quote Originally Posted by tangerinedream View Post
    cheers all
    shane
    It sounds like Tangerinedream has got a set of ATE caliper's and carriers from an A4 B6 3.0 petrol, Tangerinedream can you clarify this?
    Mar 2011
    suffolk
    249
    Quote Originally Posted by gavsman View Post
    this is spot on
  1. 312mm brake upgrade on tdi
    By iantype-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th November 2010, 19:29
  2. Cheap 312mm caliper carriers for brake upgrade
    By Jason.s in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th October 2010, 08:07
  3. 312mm brake upgrade
    By yendall24 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd May 2010, 10:28
  4. 312mm brake upgrade
    By Shug1874 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2009, 16:15
  5. My 312mm Brake upgrade.
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2005, 22:45
