Volks AutosEM Tuning
Thread: no power HELP
    Apr 2010
    329
    no power HELP
    i have just put a new( second hand)engine into my car 2001 1.9tdi. i had a look at both sides of the turbo when it was out and it looked OK,if it was blocked by soot and what ever should it be noticeable.i could also spin the shaft with no resistance so would that rule out the turbo being fooked.it seems like the turbo isnt cutting in , i can here air being drawn in under load but not to loud ,is this what is known as a boost leak? plus if it is a boost leak would it cause such a loss of power.
    Sep 2010
    167
    If u had a big boost leak it would loose a lot of power, smoke a lot too. would def have a good look around the engine for anything that maybe not connected or connected wrong first.
    Lancaster
    1,624
    Could this be a faulty N75 valve?
    What does Vagcom say?
    To do: None yet.
    Apr 2010
    329
    what is a n75 valve?
    haven't got it scanned yet
    S3 GAZ's Avatar
    Dec 2006
    Renfrewshire Scotland
    299
    There are quite a lot of vacuum hoses on the 1.9tdi. I had one that I must have knocked off when I was doing the timing belt. This caused the very same symptoms you have described. No boost and hee haw power. I found it popped it back on and right as rain
  1. Power steering fluid leak - anyone used Lucas power steering fluid leak stop?
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2011, 19:27
  2. Power to boot / install power socket
    By Kiwi Kranker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2010, 09:00
  3. Help / Advice needed, A3 1.8T, Power blipping /slight loss of power
    By Lex007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2009, 09:49
  4. No power
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th July 2005, 14:41
  5. More Power....What Next?
    By imported_jimbogrey in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2004, 10:29
