    Jan 2011
    Hemel Hempstead
    12
    Vacuum Pump fault......?
    Have a problem with my 2002 2.5tdi which is causing the turbo to overboost. There doesnt seem to be enough vacuum to close the vanes on the turbo causing it to carry on boosting when it shouldnt, especially when braking.
    There is no fault with the braking system itself and the servo appears to be working fine.
    Just recently had turbo cleaned as though sticking vanes was causing the problem but this doesnt seem to be the case, the vanes move very freely now. Also had new thrust(boost) sensor and vacuum control solenoid.
    Any ideas people...........
    Lancaster
    1,780
    Have you checked for leaks?
    To do: None yet.
  1. Brake Vacuum Pump
    By way318 in forum General Technical / How To
    Last Post: 10th February 2010, 13:12
  2. electric vacuum pump
    By gaz238 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th April 2007, 08:45
  3. Inop Vacuum Pump on 1999 Audi A4
    By missagia in forum The Welcome Section
    Last Post: 29th September 2006, 01:12
  4. vacuum pump / drive shaft
    By ajmackie in forum General Technical / How To
    Last Post: 9th October 2004, 20:44
  5. central vacuum locking pump
    By turbosk8ter in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th May 2004, 16:03
