Results 1 to 9 of 9
    Gibonz's Avatar
    Vorsprung Durch Technik
    Jun 2008
    111
    Thumbs up Removing Dash Airbag Light Bulb?
    Guys,
    Have had an airbag light on for months now in the car and I finally got the part fitted which apparently was causing it, passenger side airbag crash sensor.
    Once fitted the light has remained on much to my annoyance. An auto spark i spoke to said the problem could be in the loom and so could be costly gettin it fixed. I dont want to waste anymore money trying to get it fixed with no guarantee it will be resolved.
    I want to now pull the bulb out and be done with it.
    Is it easy enough getting at the bulb and removing it? Will it throw up any codes once the bulb is out?
    Cheers lads
    3.0 V6 Quattro LPG
    Jul 2007
    770
    Did he clear the fault if not the light will stay on .Diagnostics should say where the fault is.We have a Bora which has a fault in the wiring to the drivers seat bag which is is not worth fixing so I have blanked of the light with a small sticky pad so its no bother now .Dont think its practical to discnnect in the cluster
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    its not usaly the crash sensor its the wires
    theres a quick and simple fix for this
    as above did he clear the code ?
    what was the fault code ?
    u cant pull the bulb if you realy have to cover it with black tape
    Jan 2011
    684
    Isnt it a MOT failure for the airbag test light not to illumiate when the ignition is first turned on ? My last A4 saloon had the same fault, was the wiring loom to the drivers seat, cost about £40 to fix.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Oct 2011
    Gibonz, you do realise your Airbags are disabled while the light is on? You are in the same boat as me but getting it fixed properly would be my advice. I also certainly don't want to pay out £500+ for Audi to replace the wiring in the seat etc. But I guess we are stuck between a rock & ..
    Jul 2007
    770
    Is it true that the light will be an MOT failure from April 2012?
    Sep 2010
    167
    Yes they are going to add a whole host of updates and more failure items to the mot test, including the air bag light ,
    Good point by mike b , did you clear the faults down after the sensor was fitted? Did you inspect the wiring and multiplug to the sensor?, Im personally not a fan of covering up the light or taking bulbs out , this is my opinion.
    Jul 2007
    770
    Quote Originally Posted by quattro tony View Post
    On the bora this would mean taking the seat off cos theres no easy access underneath and I assume the other bags would function. I will have to consider this but failing this will Mot before the rule comes in to give time
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    vag com it mate, could be that the code needs clearing, i can clear it of your close to Northampton?
  1. Yellow airbag connector under seat causing airbag light to come on
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th December 2012, 18:46
  2. Removing old seat with detonated airbag. How to? Also Airbag light?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2011, 18:30
  3. HOWTO CHANGE REVERSING LIGHT BULB S LINE 8P & WHICH BULB???
    By niffty in forum General Technical / How To
    Last Post: 29th April 2010, 16:24
  4. Audi A4 avant airbag light after headlight bulb change!
    By fabtdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2010, 07:14
  5. Airbag light on dash .....
    By sprout99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2008, 17:12
