Sky InsuranceAH Fabrications
    Oct 2011
    Heater fan problem
    Basically when I turn the heat setting to "hi" and fan speed on highest setting the fan will run for a second then shut off Any one come across this problem before?
    Sep 2010
    167
    Not come across this problem tbh, you will have to have a look to see whats going on or get it looked at, could be a fault with the resistor, fan motor ,or a scan may be required of the heater control system to see if any faults logged, does it only happen when its wacked up to max? or does it work ok low and med settings?
    Oct 2011
    Quote Originally Posted by quattro tony View Post
    Yeah only seems to happen when on max
  1. Heater problem
    By 20va4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2011, 12:30
  2. Heater problem
    By Cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st April 2011, 22:16
  3. Heater problem
    By stub in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2009, 08:46
  4. heater problem
    By cjrob in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2009, 19:40
  5. A4 Heater Problem
    By a4bb in forum General Technical / How To
    Last Post: 7th June 2008, 13:48
