Sky InsuranceChris Nott
Results 1 to 19 of 19
    lockie2002's Avatar
    In the Fast Lane!
    Aug 2011
    Huddersfield, West Yorkshire
    30
    O/S Doors opened not recognised!!
    Just wondered if anyone has had this problem before and how do you solve it, when i open the doors on the drivers side my car doesnt recognise that they are open so if ive just unlocked the car and left the door open for a period of time without putting the ignition on it will lock itself also when ignition is on it doesn't show them open on the display. Passenger side all fine!
    What could it be??
    Cheers Steve
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    Door lock microswitches jammed or broken i would say. There are a few that say a squirt of wd40 in the right place will sort it if its jammed.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    mine done similar thing m8 check the wiring in the rubber boot.... between post and door mine broke inside the boot seems popular issue
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    lockie2002's Avatar
    In the Fast Lane!
    Aug 2011
    30
    ok will check these cheers where is the microswitch situated?? is it common to happen on both front and rear door at the same time or overtime don't actually know how long its been like this only had the car 2 months!
    Thanks again
    Sep 2010
    167
    Does the interior light come on when you open the doors on the drivers side, worth checking the stuffs mentioned above
    lockie2002's Avatar
    In the Fast Lane!
    Aug 2011
    30
    no they don't come on bud
    Sep 2010
    167
    It seems odd that both the drivers and the rear door is doing this if they have both gone fautly at the same time, def worth checking the wiring and lube up the locks,Im pretty sure the micro switch is located inside the door lock/latch assembly, someone can correct me if i am wrong. Also do the doors lock and unlock ok?
    lockie2002's Avatar
    In the Fast Lane!
    Aug 2011
    30
    Yeah doors all lock fine with no issues just no interior light or door open warning on the DIS!!
    Aug 2009
    Durham
    110
    Mine has this problem to but only on the passenger front door do you think it could just be the wiring loom,if not where do you squirt the wd40.
    Jul 2011
    mids
    1,193
    microswitch is in the lock mechanism itself the little plastic pin wears down over time stopping the contact, my loom broke causing this but only my drivers side front door not the rear aswell unless they linked of the power supply, i noticed mine as when i opened the door wide open my electric window stopped working and shiut the doors was working fine again
    A4 TDI 130 SPORT..
    lockie2002's Avatar
    In the Fast Lane!
    Aug 2011
    30
    The drivers door is intermittent now so I presume this is the microswith as when I bang near the latch it recognises it's open but the driver rear is still not recognised, will have a play at the weekend!
    Thanks for all your comments, really big help
    Aug 2009
    Durham
    110
    Hi still got a problem with my passenger front door,the door doesn't lock while all the others do,no interior light doesn't come on when open and it doesn't show up on dis when open either.funny thing is the window switch lights up and the window works but the red light on the edge of the doesn't light up when open.ive checked the door loom for breaks and is clear,has anyone got a clue on what it could be.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    iv got a set of lock micro mechanisums if your in need,
    Aug 2009
    Durham
    110
    Hi turkster do you think that's the problem,how much for the mechanism mate.
    Oct 2009
    Hull
    1,442
    i would check the wiring first its free to check!!
    my boot did the same not so long back and it was the wiring
    Aug 2009
    Durham
    110
    Checked the wiring all is good,need to know else it could be.
    Oct 2009
    Hull
    1,442
    either the wiring or the switch i recon so next would be switch
    Turkster's Avatar
    Dec 2007
    2,723
    try and count how many times that doors been open and closed and then add the slam's over the amont of years of service its given and then you can see why the micro switchies are busted, PM sent !
    Aug 2009
    Durham
    110
    Cheers turkster,sent you pm.
  1. Just opened pandora's box!
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st May 2010, 21:56
  2. Cd changer not recognised-- help needed
    By blas in forum In-Car Entertainment
    Last Post: 13th December 2009, 20:22
  3. USB VAG-COM Not Recognised by VAG-COM Software
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2007, 17:22
  4. CD changer not recognised
    By in forum In-Car Entertainment
    Last Post: 28th April 2005, 21:58
  5. Senna Inquiry to be re-opened!
    By amoffat in forum Motorsport
    Last Post: 30th January 2003, 12:35
