EM TuningVolks Autos
Results 1 to 9 of 9
    Sulli's Avatar
    Apr 2009
    The Ghost Town
    48
    B6 S4 Oil Change Questions
    I am planning to change the oil on my S4 this weekend. It has been on longlife (5w30), and last service was 6k ago, but I am planning to go to fixed with 5w40.
    The reason I want to do this is 2 fold - firstly I always like to have fresh oil, and I am happy to change oil every 5k miles, so this is much better than a degraded oil potentially doing 20k miles, even if it is so called longlife oil.
    Also, i had to top up recently and the Shell Helix 5w30 from Audi was £17 for 1 litre!! So if I cange the oil I will have spare to top up and it will be better priced.
    Couple of questions - what is the oil capacity on a B6 S4 4.2 when you are doing oil and filter?
    I have priced up GSF and Eurocarparts and both now do Carlube products. The Carlube Triple R 5w40 is around £26 for 5 litres and is 502.00, 503.01 and 505.00 spec so should be the right stuff - is this stuff OK?
    Any any other anomolies for the S4 oil change or any tips?
    B6 S4
    MillTech
    Uprated Brakes, Braided Lines
    Eibach ARBs
    Carbon Roof
    AMD, 351 BHP
    Best MPG 33.6
    Av MPG 25.5
    biyitch's Avatar
    Chocolate? It's doo-doo, baby!
    Southampton
    316
    Pretty much everything you need to know is here.
    Audi S4 Avant (B6, 2004) in Goodwood Green.
    Sulli69's Avatar
    Jul 2011
    23
    Thanks mate, do you know the capacity?
    Managed to get 10 litres of Triple R 5w40 f/synth 502.00, 505.00 plus filter for £52 all in!!!
    biyitch's Avatar
    Southampton
    316
    I think it's supposed to be 9.5 litres but I've never got that much in there.
    I get Fuchs Pro S 5W-40. Bit more expensive but you get what you p\y for in this case.
    Jan 2009
    I would highly recommend looking into an ester based oil.
    Mar 2009
    470
    Quote Originally Posted by biyitch View Post
    Agreed, I've just done mine and the engine took about 9.2L and I used the Fuchs too, v pleased so far.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Sulli69's Avatar
    Jul 2011
    23
    I believe that as long as it's a decent oil of the right grade, regular changes are the key, whether they are ester based oils or not - whether ester or not, changing the oil every 5-10k miles is so much better for the engine than the 19k long-life interval.
    If what I paid for a decent oil is less than half what i would have paid for an ester oil, then I can change the oil twice as often , which is the best thing for any engine.
    Sulli69's Avatar
    Jul 2011
    23
    Job done, easy enough.
    Managed to get 9 litres of oil in.
    Audi cost for fixed oil and filter service - £180.
    My cost £52, an hour and I have taken a lot more care I dare say.
    Anyone know how to reset the service interval without vag.com?
    biyitch's Avatar
    Southampton
    316
    Quote Originally Posted by Sulli69 View Post
    I can't remember the sequence but it's in the owner's manual.
  1. Lane Change - change the number of flashes from 3 to 5.
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th August 2011, 17:20
  2. Replies: 2
    Last Post: 15th December 2010, 13:03
  3. POSSIBLE CHANGE IN CAM BELT CHANGE FREQUENCY !!!
    By shilts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2010, 17:09
  4. Cambelt change, do I change the water pump
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th March 2010, 20:28
  5. change of car an got a few questions???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2007, 18:25
