Results 1 to 9 of 9
    Apr 2010
    Burnley, near monty carlo !!!
    351
    Hi all i have a MAYOR issue with inside tyre wear...Need help URGENTLY..
    Right im hoping that somebody can shed some light on this pretty big problem. As some may know i've got 19" BMW X5 alloys fitted to my car with 9J front width fitted with 225/35 tyres.
    My problem is the inside edge of the drivers side has worn and i do mean worn a big groove into the the top edge of the tyre adout 25mm long going into the tread, in other words if you look @ the tyre on the inside edge the groove goes 25mm towards the outside face of the tyre + about 20mm deep!!!!!
    Its not tracking as its way way to harsh + deep and the tyre has only done maybe 3000 miles, the passenger side is completely un touched not a mark on the inside edge @ all........On full lock nothing catches everythings clear by some margin + its clear of the inner plastic arch. The top ball joint is above the tyre and clear by about 20mm as @ first i thought it was that, that was rubbing but it appears well clear.
    Would a knackered bearing or worn rubber bush affect the ball joint so much, its got me as the passenger side is just the same but hasn't an ounce of wear on it + its clear of the suspension strut and all the gubbins...
    Anybody any ideas as im currently looking for a new tyre + looking @ a big bill from a garage....
    Cheers all
    A4 TDI SPORT with full leather and thats it as standard.Fitted by me.Remap,S-LINE BADGES.S4 Wing mirrors.DIS,Seat Cupra splitter.Rear parking sensors.5k hids+LED side lights+DRL lights+chrome indicator bulbs,amber fog lights.LED Xenon number plate bulbs,upper/lower front grills+boot strip in matt black.Ipod dock.19" BMW X5 SPORT CONCAVE ALLOYS,9 J FRONT 10 J REAR 20mm hub adapters front ET 28,18mm hub adapters rear ET 27.
    TO DO.B5 spring perches.Renault rear diffuser?? S/S exhaust.
    Oct 2009
    Hull
    1,433
    im not saying you have eaten all the pies or anything but have you sat in it and got someone to check to see if anything is close?
    it could be the extra weight of driver coupled with suspension travel causing it to rub on something
    Apr 2010
    351
    Tryed that its still along way to the tyre and we were pushing down hard on the front wing like hitting a pot hole hard......
    S3 GAZ's Avatar
    Dec 2006
    Renfrewshire Scotland
    299
    Get some pics up of damage and of the car. It sounds like the damage I had on my decked punto Gt when I had 16's on it lol. It was the rear arch catching. I couldn't really hear it due to road noise so beware just cause u can't hear it doesnt mean it ain't catching.
    And I imagine it's near impossible to simulate how much the suspension travels by pressing down on the wings. Try bumping the said wheel up on a kerb and get someone to watch.
    simon.m's Avatar
    Oct 2009
    2,746
    or you can jack the othere side up to push down on the side thats rubbing you should still be ok to see or use a mirro
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    any play in the top balljoints?
    post some photos of the damage.
    TD5 Land Rover Defender build
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    im still thinking tracking have you had it checked at all ?
    nickb834's Avatar
    Oct 2010
    40
    Quote Originally Posted by holmefield View Post
    Cheers all
    I had this EXACT same issue, wrecked a T1R in about the same mileage.
    I had creaking suspension when moving at low speeds (think multi story car park), and a slightly jittery ride - replaced all my front arms with OEM arms and had tracking done (Out by country mile after the arms done, no idea beforehand) and the problem is gone.
    The handling sorted out nicely to boot and I'm not wrecking 125 quid tyres every 3k miles.
    So in your case - I'd jack the front up (my fav method is axle stands with blocks of wood with slots in em - on the sill jacking points) - take the wheels off, and use a pry bar / crowbar / whatever to check for play in your joints.
    If you've never had the arms changed on the car and it's on it's first set they're probably shagged by now - you can get a full OEM set (not ****ty chinese crap off fleabay) for about £500, bit more if you go for the track rod ends (mad not to IMHO) shop around, but the diff will be night and day when fitted.
    Be warned! if you are doing this yourself, the top pinch bolt for the upper arms is a right bast4rd to get out - steel bolt in an alloy casting = corrosion magnet! You will need plenty of heat and patience - about an hour in my case to get one out.
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,275
    Camber angle
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
  1. Rear tyre wear issue on non-quattro car!
    By AndymacA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd March 2009, 20:57
  2. 2nd Service, Rear tyre, inside excessive wear
    By giblets46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2008, 10:50
  3. Help - Looking for this front bumper urgently - Pic Inside
    By Manny_K in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2008, 15:22
  4. Inside tyre wear on -40mm lowered C5 A6
    By evomaster3000 in forum Handling
    Last Post: 26th March 2007, 16:48
  5. Help - Serious wear on the inside edges of front tyres.
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2006, 15:36
