AH FabricationsEM Tuning
    Apr 2010
    Burnley, near monty carlo !!!
    351
    Just a quick ask, with regard to OIL change???
    Hi all im going to change my oil and do my oil filter today ( which is a paper one ) last time i did oil filters you put a screw driver through the metal one and undid it!!!
    Anyhow is there anything that i need to do when changing it or is it all just standard stuff.???
    Its a 130 BHP TDI SPORT model...........Wheres the oil filter located is it @ the back???
    Cheers all......
    A4 TDI SPORT with full leather and thats it as standard.Fitted by me.Remap,S-LINE BADGES.S4 Wing mirrors.DIS,Seat Cupra splitter.Rear parking sensors.5k hids+LED side lights+DRL lights+chrome indicator bulbs,amber fog lights.LED Xenon number plate bulbs,upper/lower front grills+boot strip in matt black.Ipod dock.19" BMW X5 SPORT CONCAVE ALLOYS,9 J FRONT 10 J REAR 20mm hub adapters front ET 28,18mm hub adapters rear ET 27.
    TO DO.B5 spring perches.Renault rear diffuser?? S/S exhaust.
    kev1000's Avatar
    Jun 2011
    County Cork, Ireland
    194
    When I take off my oil filter I wrap a piece of sandpaper around it (grit against filter) and twist.
    A lot less messier than putting a screwdriver through it and if you getthe screwdriver way wrong you'll end up ripping the filter apart.
    The position of filter on my car (1.8t) is, when I'm facing front of car, it's on my right.
    If u find the filter too tight using the sandpaper method, some trips to the Gym are required
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    been a while since i changed mine, but it theres not a bolt head on the filter housing i use an oil filter claw
    Clarke Quality 2 Way Oil Filter Remover Wrench Claw | eBay
    Apr 2010
    351
    Quote Originally Posted by scott b View Post
    Cheers as you look @ the engine, wheres the oil filter ? is it on the left, right or @ the bottom @ the back?
  1. Just a Quick one with regard to head units??? As its twisting my melon man!!!!
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2011, 17:08
  2. Urgent help needed with regard to passenger airbag..
    Last Post: 19th May 2010, 21:56
  3. Engine Change - Quick Question...
    By christinho in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2008, 21:24
  4. fnal bit of advice with regard to fitting HU
    By chris_20 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2006, 21:01
  5. quick oil change question
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2006, 17:31
