Volks AutosChris Nott
Results 1 to 18 of 18
    imported_ChristianF
    Xenon Headlights - Sidelight change
    I have a 2004 A4 with xenons, but the sidelights are crap, they look yellow in comparison with the white light of the headlights, I have seen several different types of bulbs that claim to be compatible and look more like the xenon, but have read differing opinions on their performance.
    Has anyone fitted these sorts of bulbs and can recommend a decent set?
    imported_ronny
    Re: Xenon Headlights - Sidelight change
    Get some While LED's thats your best bet, they look better than the yellow of the standard ones, I have not got them yet, but will do.
    Nov 2004
    London UK
    2,614
    Do you know where to get the white LEDs Ronny>???
    Apr 2004
    North East Uk
    54
    got some leds for my A4 from ace parts four leds need to modify them so they will fit but not to sure if they will work put some in my wifes A3 which has w5w fitting the looked great until i switched the Xenons on and they went off dash showed bulb failure no one does a h6w fitting side light apart from tanturmwerks in the USA but they look like ba9 that have been changed.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    I use PIAA extreme white sidelight bulbs their an exact match to mine!
    http://www.a-pp.com/shop/piaa_xtreme.htm
    Cheers [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    scoTTy's Avatar
    Essex, UK
    1,958
    I want to do this as well but after having a look I think I need to pull the head light out. There's not a lot of space with the V8 in the engine bay. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    I wouldnt bother with the LED's the PIAA's are a great match i'll take a piccy some night this week. their 10 quid but worth it.
    Nov 2004
    London UK
    2,614
    I bought those Xenon ones off ebay ages ago....the ones advertised with foglights. Aint even fitted them i think they will be pants to be honest so aint bothered! only 3900K brightness anyhow [img]/ubbthreads/images/graemlins/bang.gif[/img]
    Nov 2004
    London UK
    2,614
    Might give the ones ago which u have suggested Derek. [img]/ubbthreads/images/graemlins/ok.gif[/img]
    imported_bubstar
    I'm using Philips Blue Vision sides - H6W - in Xenon headlamps . They're very good, look almost white . I've got Osram Silverstars - H7- in the mains again no complaints very white compared to the normal OE main bulbs. If you have full DIS with bulb out warning don't bother with LED's they'll send the DIS crazy!! I got some rear stop/tails - just flashed when fitted , the Mrs has them in her Clio now [img]/ubbthreads/images/graemlins/thumbsdown.gif[/img]
    Nov 2004
    London UK
    2,614
    I have full DIS can you just tell me what are the best bulbs and what i need for everything at the front.....main beam, dipped, whatever i need for best xenon effect! cool guys thanks much appreciated [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    The PIAA bulbs if you can afford are the best imho.
    Nov 2004
    London UK
    2,614
    What H218 and H222 then? I have no idea [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    Apr 2004
    North East Uk
    54
    Derek, what bulb fitting do you have on your car? I also have the phillips blue sidelight bulbs fitted, not too impressed.The ones from a company called HOEN may be worth a look, they do lots of different fittments and have quite a good web site.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    H222 - W5W Wedge 5=10W no need to look for others these are an exact match
    imported_ChristianF
    I can't get PIAA bulbs to fit my car, what alternatives do I have, the Phillips ones seem to have a mixed opinion....
    Apr 2004
    North East Uk
    54
    scoTTy's Avatar
    Essex, UK
    1,958
    Frank,
    Did you remove the headlight or access it from the rear? I had a look at the latter option and couldn't see a way to do it.
