Results 1 to 7 of 7
    baynesey's Avatar
    well you better unsell them, sharpish!
    Mar 2007
    Stevenage, Herts
    194
    Cam Timing, is this correct?
    Please see pictures below, they are set to TDC, however are they out of line? as it is it will not turn over when turning over the bottom crack, something hits (valve against piston I would assume).
    Should I be able access the head bolts with out spinning either cam if set to TDC?
    Engine is a 2.0 FSI AWA
    Chris
    2003 2.0 FSI SE A4 Avant
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    no mechanics in the house then
    Sep 2011
    23
    hi mate, the cam looks correct but on the crank are you sure you are not 180 degrees out? because its 2 revolutions on the crank compaired to 1 revolution on the cam. the easiest way to tell is take number 1 spark plug out and put a thin rod down the spark plug hole and try turning it over BY HAND to makesure the rod comes up to its highest point.
    hope this might help
    Jan 2011
    northants
    165
    cam timing looks incorrect from pictures
    suspect the chain has jumped at the back of cams
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    1 yes and 1 no, anymore input guys
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    as c5 quattroa states check no1 piston is fully to the top by using a thin object down the plug hole or even a good eye and a torch, then make sure the crank is definatly lined up and then you will need to check the second cam is also timed up on the rear chain......
    is there more info in to why it's in pieces m8 ??? was it running ok and somethinks gone wrong or you brought it like this ???
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    Quote Originally Posted by marktdisport View Post
    My cambelt snapped three weeks ago, smashing the valves, rockers etc, if the Cams are aligned in the Head does it matter if the Pulley suggests TDC markings are out if they have been setup out of the original TDC markings?
    previous thread; What are my options? Cambelt Failure.
  1. Correct oil for 98 1.8T?
    By sprint_48 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2010, 11:54
  2. Correct oil?
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2009, 10:53
  3. Is this correct?
    By RyanGolfGTTDi in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2009, 00:16
  4. What is the correct timing belt interval for an A4 1.8 20 valve?
    By Donald_MacIver in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2007, 20:30
  5. 2.8 Timing Belt or timing Chain ????
    By RichbagggA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2003, 07:10
