Thread: P1292
    Aug 2011
    33
    P1292
    So I keep pulling a P1292 code and I think my fan runs even when its not so hot or even the temp outside is cool...and I wanted to know what to check BEFORE I go about thinking it's the actual thermostat itself. I have replaced the coolant temp sensor behind the engine by the firewall and that has fixed my screwy temp gauge. Also if it happens to be the thermostat I have an extended warranty and would this be covered?
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    From the Ross-Tech website:
    17700/P1292/004754 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Fuse(s) faulty
    • Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265) faulty
    • Map Controlled Engine Cooling Thermostat (F265) faulty
    Possible Solutions
    • Check Fuse(s)
    • Check Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265)
    • Check/Replace Map Controlled Engine Cooling Thermostat (F265)
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Aug 2011
    33
    Ok, so it's basically the thermostat? :/
Tags for this Thread
