AH FabricationsChris Nott
Results 1 to 13 of 13
    Aug 2009
    Durham
    110
    Changing rear door triangle trim?
    Hi guys my a4 tdi 130 is in for a respay, so I'm stripping everything off.question ive got is how do you take off the black triangular trim that corrodes on the rear doors,Its got me beat.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,685
    Isn't it held on by a bolt from inside? I think you need to remove some trim to access it.
    Aug 2009
    Durham
    110
    Do you have to take the door card off to do this,also does anyone know the part number for this.
    Mar 2008
    Dorset
    13,685
    Saloon or Avant?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,648
    Is it the same set up as the B5s?
    If it is, you remove the plastic trim (keep the door cards on, its a bit wiggely but it works), with that off you have 1 torx bolt, undo this and the metal panel will be loose, wiggle and lift and it will come off.
    A clip & rear window trim
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,578
    not sure about about the fastest way to do it but I have been told that the B5 and B6 are VERY different and I know Audi quoted 2hrs per door + parts (new metal trim and clips) to fix it.... can't rememebr if they were £10 each tor £20, but it stick in my head "£40 for 2 metal triangles, but about £400 to fit them!"....
    LostBok/BahnStormer77
    Aug 2009
    Durham
    110
    Thanks for the help guys i'l give it a go and see what happens,I've took the plastic trim off and there is a grub screw there so here's hoping it's that easy.
    BahnStormer
    Feb 2009
    Surrey
    2,578
    would be great if you could get some pics to help with a "how to" guide....
    I think the problem is that you need to get the door card off to get to the bolt - but like I said, I've not actually done this myself - I have had the new parts sat in a box at home for about 2yrs! I can't afford to have my car out of commission, so have never had the balls to have a go at it myself.
    Aug 2009
    Durham
    110
    Do you have part numbers for them mate.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,648
    Quote Originally Posted by choimaloy View Post
    paulsb's Avatar
    May 2010
    lanarkshire, Scotland,
    138
    i read somewhere you have to remove the door card then remove the top frame off the door to get to 2 bolts but it was a while ago that i looked into it.
    btw they where £25 each from audi.
    BahnStormer
    Feb 2009
    Surrey
    2,578
    so 2 yrs ago, £20 each sounds about right... in which case, I'm pretty sure Audi quoted about £400 for the labour to fit them...
    Aug 2009
    Durham
    110
    does anybody have a diy guide as ive got the the back and it looks brand new apart from that black trim that lets it down.I really need to buy 2 just to finish car off nicely.
  1. 2010 A6 rear door trim removal
    By slepy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th June 2011, 23:53
  2. rear door - corner window trim
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2010, 20:49
  3. Changing the cloth/leather trim on door cards?
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 20:01
  4. changing a door or door skin
    By hannakournikova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th October 2008, 11:41
  5. Painting rear door trim pieces
    By shineydave in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th November 2007, 16:36
