JMB RetrofitsVolks Autos
Results 1 to 10 of 10
    Oct 2009
    50
    Water in passenger floor?
    Hello there, just been out in my 02 avant 3.0Q and noticed lots of drips of water on the passenger mat - it was as if someone had spilt a glass of water there, had a look in and its dripping in from in behind the glovebox somewhere.. Can anybody shed some light on this? Im guessing its a drain hole blocked for the aircon? when i got the car the scuttle panel was chock full of leaves and bits of tree etc, cleared most of it but not sure how to get at the rest as its covered in plastic!
    gavsman's Avatar
    Sep 2011
    379
    Could be the Plenum Chamber problem? hopefully not, someone else may be able to shed some light on it.
    Plenum Chamber Drain Grommets - Every A4 B6 owner is affected by this common fault
    Jul 2007
    770
    Does the aircon leave a puddle under the car when its full on and stationary?If not it should be the drain but I would get the Plenum chamber cleaned out asap anyway
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Agreed, it will be one of those two things (unless you have a sunroof?), plenum chamber most likely.
    Oct 2009
    50
    Thanks for the replies - no sunroof, not sure about any puddles from the aircon as i live in scotland and its always fookin wet lol. Will pop to Audi in the morn and see if they will do the plenum recall. There is a heap of leaves and foliage etc in the scuttle but i cant get to it.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Quote Originally Posted by Padz View Post
    wet n dry vacuum at the local garage will work wonders if they wont do it for free.
    Oct 2009
    50
    So is it a big problem or no? I mean im ok to drive the car for now?
    Oct 2009
    50
    Just to bump this and i also went to audi today they told me its had the plenum recall. The floor is still wet but i used a wet n dry vac to help. Put the aircon on to demist the windows and a weird smell came out - is it the pollen filter?
    Someone please help
    Mar 2008
    Dorset
    13,856
    Probably the pollen filter got contaminated by the water. I'd replace that, and also check that the evaporator drain is clear. Then get some Wynn's Airco or similar to deodorise the system.
    Oct 2009
    50
    Thanks for all your advice. You should be called the oracle.
  1. water leaking in the passenger footwell
    By stimpy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th January 2011, 22:28
  2. Water in the Rear Passenger footwell
    By jPwatts in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th April 2009, 20:58
  3. water leak in passenger footwell
    By KevM3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th December 2007, 15:38
  4. Water leak behind passenger seat?
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2006, 11:41
  5. water leaking passenger footwell
    By solihul in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2006, 21:43
