Results 1 to 19 of 19
    SerialAudiOffender
    Aug 2010
    Scotland
    100
    Where best to get Sat Nav Disc?
    Hi there, hopefully someone can help me out here. My RNS is not reading my Disc properly and comes up with a disc error, so I'm not wanting to pay extortionate amounts of money for a replacement disc in case it turns out to be a problem with the actual RNS head unit. Could any kind person point me in the right direction of where to buy a version of the map disc at a decent price please?
    Many thanks for any assistance, Phil.
    gavsman's Avatar
    Sep 2011
    379
    Before paying out for a new Map disc....could you not try using a dvd/cd cleaning disc to see if that solves the prob?
    May 2011
    225
    naughty, but for testing if its a head unit or disc fault... The Pirate Bay - The world's most resilient bittorrent site
    2002 B6 A4 1.9 TDi 130 Sport with fully factory Votex kit.
    Currently standard
    SerialAudiOffender
    Aug 2010
    Scotland
    100
    Cheers guys, I'll need to try just cleaning the laser for now. I'm not able to burn anything Dual Layer, so can't even give that a try :o(
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
    mine plays up now and again but a bit of t-cut on it and its right as rain
    SerialAudiOffender
    Aug 2010
    Scotland
    100
    Quote Originally Posted by voorhees View Post
    Is this for real? T-cut the back of a DVD? What's the script, how heavy/light?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
    Quote Originally Posted by Phil MC View Post
    Ermm the front...back would be no good would it.Just a light smear
    Jul 2011
    Buckinghamshire
    55
    what year Disc?
    SerialAudiOffender
    Aug 2010
    Scotland
    100
    Quote Originally Posted by carlos19664 View Post
    what year Disc?
    Hi Carlos, its the 2010 disc thats in it at the moment but really any one would do for diagnosis purposes?
    SerialAudiOffender
    Aug 2010
    Scotland
    100
    ok guys, bear with me here.
    I've tried :
    1) cleaning the laser, no joy.
    2) Playing other cd's & media, all ok, so not the optical reader at fault.
    3) t-cutting the nav disk, still saying that there's a disc error when trying to use the nav disc.
    So I reckon that it is definitely another Nav Disc that I need, just need to borrow a Back-up Nav Disc to confirm this is the case....HELP Please!!!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Is it a genuine disc Phil? know very little about RNS, but have heard that they don't always read copied discs?
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    You need to use an original Audi DVD map disc for proper testing - any year will do so you can confirm if the "DVD" laser is good or bad.
    The fact that it plays CD's is not an indication that the DVD laser is working - a different frequency laser is used for CD versus DVD reading.
    DVD copies are harder to read than original "print" DVD's and make your laser work harder all the time, so it's best for your RNS-E to have an original disc.
    Ebay is a good source for map DVD's - you pay a premium for current year disk but one year old discs are pretty cheap at £60~£70. Older discs are even cheaper.
    Don't waste your time on copies they will fail at some point and reduce the life of your laser.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    343
    I am having the same problem. Although I'm using a 2004 disc so it's no wonder.
    Nov 2007
    Under the Forth Bridge
    16
    Quote Originally Posted by S3 GAZ View Post
    2004 disc - nice one Gaz, at least you'll be able to find your nearest Woolworths in the special destinations...
    But seriously I had the same issue with a 'backup disc', initially lens cleaning worked, but nav got progressively less usable, started with stalling then unreadable error. In the end I got a genuine 2nd hand disc from ebay and haven't had a problem since (over a year now).
    27,087
    1st of all, is this an RNS D or E as B6 didnt come with E units.
    S3 GAZ's Avatar
    Dec 2006
    343
    Mines is an RNS-e. I'm sure it was in mines from the factory. I have an 04 plate sport. It has also got aero wipers.
    gavsman's Avatar
    Sep 2011
    379
    27,087
    Strange as I had a B6 & that was rns-d & never known a B6 with rns-e from factory, will go check few things now.
    S3 GAZ's Avatar
    Dec 2006
    343
    You may well be right mate. Perhaps a previous owner retro fitted it. It came from derby Audi like that though.
  1. RNS-E Upgrade from 2009 Sat Nav disc to 2011 Sat Nav disc
    By pluves1 in forum Satellite Navigation
    Last Post: 23rd June 2011, 19:19
  2. RNS-E SAT NAV DISC
    By zortan2007 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st October 2010, 22:11
  3. Replies: 3
    Last Post: 14th August 2010, 07:51
  4. Tax disc from old car
    By Chris28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2009, 19:55
  5. sat nav disc
    By FazS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2008, 21:12
