EM TuningVolks Autos
Results 1 to 25 of 25
    boya's Avatar
    Aug 2009
    consett county durham
    394
    Blanking egr on 2.5
    I fancy giving this a go but just wanted to double check, in the pic do I remove the pipe with the White sleeving under the egr and blank it at both ends or am I completely wrong lol!
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    i blanked mine at the end which joins the egr, i see no reason to do both ends of the pipe as one plate stops the flow of air in the system
    mikeh126's Avatar
    Preston, UK
    152
    I did the same - just one plate in between the egr and the pipe with white sleeving.
    No need for two - one plate will suffice to blank off the flow of gases to the inlet manifold.
    I noticed a slight gain in performance after fitting it - definitely more responsive.
    2003 A4 Avant 2.5TDi 180 Quattro Sport in Light Metallic Silver, Remapped to 220 by ProTec Motorsport, RS4 18" x 8J reps, Falken F452 tyres, 10mm H+R Spacers, Matt Aluminium Mirror Covers, Heated Mirrors, S4 Door Blades, Continental TS830p Winter Tyres on 5 star 17" Sport Alloys
    boya's Avatar
    Aug 2009
    394
    So am I right in thinking that you remove the pipe with the White sleeving and place the planking plate where I have put the red arrow??
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    correct heres a photo of fitted plate
    paulsaudi's Avatar
    Jun 2011
    71
    Can you not just pull the vac pipe off and block it??? keeps valve shut i am led to believe???
    Audi A4 B6, Dolphin Grey, Full Votex Kit, 19" RS6 Alloys, Lowered 20mm, RS 3" Twin Exhausts, Chrome Mirror covers, Carbon Wrapped Grill, Cupra R Splitter, Wolfsburg Number Plate Surrounds, RNS-D Sat Nav, Full Colour D.I.S, Black Leather..........
    rockinred's Avatar
    Sep 2011
    9
    is only certain models/years you can do this to ive had my dpf removed but the egr is still there and not blocked i got a 56 plate A4 2.0 tdi 170
    rockinred's Avatar
    Sep 2011
    9
    i mean is possible for me to do it to my car.
    Audi A4 avant 2.0 tdi sline 170 bhp 2006
    Sep 2011
    West Sussex, UK
    111
    Hi guys, possibly a dopey newbie question, just wondering why you would want to blank this off?
    boya's Avatar
    Aug 2009
    394
    Quote Originally Posted by swarcup View Post
    Ahhh I thought the pipe was removed all together and a blanking plate made lol!! So basically a thin piece of steel to slide in the gap is all I need with a couple of holes in it for the bolts?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    yep thats it, i would use a piece of steel around 2mm thick as ive heard stories of these burning through when thin metal has been used. if you are making your own then i would remove the pipe and trace around it as a template.
    paul100 the reason for blanking it off is to remove all the used exhaust gas from re-entering the engine and taking some crud with it. the idea behind the egr valve is to recycle used exhaust gasses back through the engine to improve emissions, Who decided that doing this would do your engine any good?
    Doing this has definately improved the response of the engine and also i put mine through the mot with it in place and still passed the emisions test with flying colours.
    deffinately worth it as there should be no or very little crud re entering the engine
    mikeh126's Avatar
    Preston, UK
    152
    Quote Originally Posted by boya View Post
    I bought mine off the Bay - it only cost £2.95, 3mm thick, and made for the job - correct size, with holes already drilled.
    Search the Bay for 'Audi egr blanking plate'. There'll be plenty.
    boya's Avatar
    Aug 2009
    394
    Cheers chaps, am a engineer so I will swiftly knock one of these up at work out of titanium sheet, (no chance that will burn through) anyway thanks again and I will get results up ASAP!
    ADC74's Avatar
    Master Baker
    Jan 2011
    Staffordshire
    148
    Does the actual EGR VALVE need to be cleaned for this mod to be effective or do you just apply the blanking plate ?
    ATR vs V6 TDI
    boya's Avatar
    Aug 2009
    394
    Quote Originally Posted by ADC74 View Post
    Good question... Because it's not working anymore I wouldn't of thought so. (waiting to be corrected)
    will89's Avatar
    Jul 2010
    362
    I have just ordered a blanking plate for mine. Does it effect the fuel economy at all?
    boya's Avatar
    Aug 2009
    394
    Quote Originally Posted by will89 View Post
    Apparently it gets better in warm weather and worse in the cold, not Much at all though.
    Dec 2010
    Huddersfield
    30
    Does the vacuum pipe need removing or can it be left connected as in the pic above with the plate fitted. I have fitted the plate but also removed the pipe which I think is the reason my engine warning light is on.
    boya's Avatar
    Aug 2009
    394
    I haven't got round to fitting the plate yet but I have disconnected the vacuum pipe and mine is fine.
    mikeh126's Avatar
    Preston, UK
    152
    Quote Originally Posted by pbwatch View Post
    The vacuum pipe can be left fitted - with the blanking plate fitted, it doesn't make any difference.
    Before I fitted the plate, I disconnected the vacuum pipe - and the Engine Management Light hasn't come on, either with just the pipe disconnected, or with the blanking plate fitted.
    Could the light be for another, unrelated reason?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    i left everything connected, i didnt see any reason to remove it
    boya's Avatar
    Aug 2009
    394
    Once I get the plate made I will re connect the vacuum to the egr as it's not going to be doing anything anyway.
    Dec 2010
    Huddersfield
    30
    On my car the light comes on if I remove the vacuum pipe and there is no other reason it would as it's been checked for codes and If I reconnect it goes off after a little while.
    I have blanked the EGR at only one end as in the above pic but if I re-fit the vac pipe, the power reduces slightly and does not run great again. Pipe removed and it is as smooth as silk and up on throttle response.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    I have read about this it seems to happen for some and not others, Try disconnecting the vac pipe but blocking it up, it may help
    Dec 2010
    Huddersfield
    30
    Yeah I did block it up but still does it! strange!
  1. EGR blanking plates
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2011, 09:01
  2. egr blanking
    By r3stu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2010, 22:43
  3. Blanking for CD Changer???
    By thedozyone in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st June 2009, 21:47
  4. interior blanking cap
    By rasA4 in forum Parts Requests
    Last Post: 26th March 2009, 21:12
  5. EGR Blanking cap
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 14:45
