JMB RetrofitsBadger5
Results 1 to 7 of 7
    deburgh999's Avatar
    Feb 2011
    64
    Audi a4 b6 1.8t fan help
    hi, recently when i start the car from cold the fan kicks straight in and takes awhile to go off, has anyone ever come across this and what fix was needed.
    Chris
    kite's Avatar
    Oct 2007
    East Berks
    675
    turn the aircon off and see if it stops the fan running...
    A4 (b6) 2.5 TDi QS Saloon.
    Phil-UK's Avatar
    Mar 2011
    Devon
    22
    Which fan? It could be the secondary air fan that comes on when you start from cold. It blows air into the exhaust and last for about a minute then stops, can sound like a Hoover at times and sounds like a jet engine when spinning down if you turn the engine off before it's turned itself off. If it's this fan it's normal behaviour.
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    Could be a problem with one of the temperature sensors, have you got access to vag com or can someone scan it for you??
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    deburgh999's Avatar
    Feb 2011
    64
    unfortunatly i havent got vag com, is it recomended to download? which fan now, your asking. ill try to get it plugged in somewhere to find out what errors there might be. i never have the air con on so i know its not that and it doesnt always do it, this morning it was fine, not aure whether it is linked to my car sometimes will only boost to 5 psi then other days will go upto 8, got to get it to a specialist.
    Oct 2008
    West Bromwich
    42
    Most certainly the coolant temp sensor. Our cars have three. If a 1.8T its probably the g62 sensor thats located by the bulkhead. I have recently had to replace mine. It sounds as if its on the way out.
    The fans kick in from cold, the car lacks power, and the engine light will come on soon enough.
    The fuel consumption can get worse and sometimes it may not start if you have not warmed it fully first.
    Its a cheap fix, about £35 from the dealers. There are cheap copies about but they are false economy.
    Heres the part number off ETKA
    059 919 501A
    Its fiddley but easy enough to do by yourself. You will have to get some jubile clips as you will have to break the "one use only" factory clamps.
    Good Luck
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
