EM TuningMonster Motorsport
Results 1 to 8 of 8
Thread: 2002 1.8T Boost
    Dec 2009
    37
    2002 1.8T Boost
    Hiya Guys,
    Owned my 2002 Audi A4 1.8T Sport since April. The car is in excellent condition and used every day.. Car runs great and is nippy enough but I am 100% sure I am getting no boost. Just seems like a NA car (I've owned two standard 1.8Ts Golfs in the past)
    I've replaced the MAF and DV but there is no difference.
    Reading up on Forums I am now looking at Cleaning the Throttle Body (although this only seems to help with idle) and looking at the N75 valve and the WasteGate Actuator.
    Anyone know a good way to test these parts to see if they are broken?
    I have had the odd EML but currently all clear.. I know, I need to get them read and will get this done in the near future.
    Any Help appreciated
    Jay
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    to save you money
    get it pluged in 1st
    to save just swapping parts
    warren_S5's Avatar
    Oct 2007
    7,164
    I've read somewhere on the net taht if you remove the vacuum line from the N75 to the wastegate actuator you basically disable the wastegate actuator - the wastegate will not open. The boost should be higher as it is no longer being limited. If you go WOT (Wide open throttle) you run the risk of overboosting and running lean or detonating, so drive the car with the hose disconnected, but do NOT under any circumstances go full throttle.
    If you remove the line and are able to achieve the correct amount of boost (whilst being careful not to overboost) then it may be a bad N75.
    If you remove the line and it runs the same then you have a wastegate problem, turbo problem, or a large boost leak.
    Even if you don't have a CEL, check the codes first before you do anything else. Not all codes trigger a CEL. Could be soft limp mode or something.
    Audi S5 3.0V6T Coupe Black Edition
    Dec 2009
    37
    Cheers Guys.. Will try the Vacuum line test tonight.. No worry about over boosting.. I'll pop it off and if I even feel the slightest boost I'll be a happy man and reconnect before replacing the part.
    Has anyone purchased a VAG COM cable from Ebay? Does the 2002 Audi have the 16 Pin Connector?
    Jay
    Dec 2009
    37
    Just completed Warrens idea and disconnected the top vacuum pipe from the N75.
    For the 1st time since purchasing my car in April I felt the Turbo and it pulled well :-)
    Cleaned out the throttle body and re-connected the pipe and the cars running well now but no boost again.
    At least the test seemed to prove the turbo is ok :-)
    Has anyone had these symptons with there car? Was it the N75 at fault or another reason (soft limp mode?)
    I've ordered a VAG COM cable but wont arrive till later this week.
    Jay
    MDA
    sploorer
    Dec 2009
    87
    hope you get it sorted fella
    mines a 2002 1.8T it pulls from about 1900rpm and pulls like a train
    run a couple of tanks of v power through it when you have it sorted
    runs even better
    matt
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    It sounds like the N75 to me.
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    I had the same problem. I think it was about £40 from the stealers...
