Results 1 to 9 of 9
Thread: Door locking
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    435
    Door locking
    My drivers door will not lock when I use the remote, it locks everything else apart from that. But it works when I use the key. Any ideas what's the problem??????
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
    East Sussex
    I discovered last night that mine is doing the same thing!!! The remote locks/unlocks all the other doors but the driver's one can only be locked and/or unlocked by using the key in the lock.
    I'm hoping some WD-40 to somewhere readily accessible will do the trick but not holding my breath...
    27,028
    Given works with key, check the loom going into the door for any damage, as it may not be getting the signal to lock or unlock.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,424
    as above
    very comon problem
    Oct 2009
    Hull
    1,437
    again as above
    but also check all the pins in the connecting plug mine had all corroded and snepped off!!
    Aug 2011
    I've had this too, let us know if you find out the cause. cheers
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    I have this too, and now it's also happening on the passenger side as well. The passenger lock is more painful as I have to use the key and push it into a slot when the door is opened. I must check wiring looms before I go and buy new locks.
    B6 A4 1.9TDi 130Bhp, 18" RS6 Reps, iPod ICELink, S4 Grill, S4 Door Flares
    itsmeagain's Avatar
    Mar 2010
    West Midlands
    435
    Gonna have another look at the loom running thru the door, I did check this before but couldn't see anything faulty.
    bez101's Avatar
    Jul 2008
    8,424
    Quote Originally Posted by itsmeagain View Post
    you need to have a very close look
    they sometimes look connected
    give the wires a tug 1 by 1 if 1 is broken you will find it that way
