EM TuningSky Insurance
Results 1 to 11 of 11
    Apr 2010
    333
    boot lock problem
    hi all can any one help.
    2001 a4 b6
    my boot will not open when i pull the handle,i have to use the button on the key and even at that it only opens sometimes,i took off the liner to have a look tonight,the actuator if that is what you would call it the thing that pulls the metal rod to release the boot only works sometimes and other times it only pulls the rod half way (one problem)when i disconnected the wire to the back of the handle the handle will work but when its connected it wont work. so any one any ideas.
    Lancaster
    1,629
    The micro switch will have died on the button.
    someone with abit more knowledge will be along shortly though.
    To do: None yet.
    Apr 2010
    333
    i was looking through a few threads about it but there is'nt much info hopefully some one will have a diy guide
    190 S LINE QUATTRO
    somerset
    81
    If the micro-switch has died like mine did, i did a really good repair. I bought a new micro-switch from maplins for £1.50, remove the complete numberplate light assy (aluminium on early B6's and plastic on 2004 onwards, due to numberplate light screws corroding in) and using a metal pick, picked out all the original potting, unsolder the connections, (only 2 of the 3 are used) and solder new micro-switch in. Check the NO/NC (normally open/ normally closed) connections as they were the opposite way around on the new switch, all i did was to put a link wire across to the correct pin. Check it all works by using a multimeter with a continuity bleeper (should bleep when pressed in) and re-pot using araldite or silicone sealant. When back on the car i had to bend the actuating tab on the micro-switch to get it to work in the correct place. My boot now works better than it ever has done, just a touch on the rubber pad and she opens....
    Apr 2010
    333
    by any chance do you have a pic of the micro switch,i have no idea what it looks like
    190 S LINE QUATTRO
    somerset
    81
    Sorry, no i have not, i did the job at work during lunch so had to rush it a bit, once you have removed the black plastic bit that holds the numberplate lights it will all become clear, it's in 2 bits, i think there are some self tappers to remove, then it will all separate, the micro-switch will be visible, a haynes manual will be handy.
    Apr 2010
    333
    would this be the reason for the too problems or is it possible i need a new actuator as well.why is it that when i disconnected the wires it will work by the handle
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    I had the exact same issue about 2 years ago. I bought a new actuator and fitted it. Very simple fix, worked straight away. I tried all the usual first with penetrating fluid etc..but the actuator was shagged.
    B6 A4 1.9TDi 130Bhp, 18" RS6 Reps, iPod ICELink, S4 Grill, S4 Door Flares
    190 S LINE QUATTRO
    somerset
    81
    If the actuator has had it the boot won't open with the keyfob either. Mine worked ok with the key fob so i knew it was the micro-switch.
    Apr 2010
    333
    sorry just checked again it is the wire that is plugged into the back of the key barrel that when unplugged the handle will work.the actuator works but it seems week but will open some times,it is pulling the rod slightly and releasing again.when i unplugged the wire last night i noticed that my hazard warning light comes on when i open the door or boot is that normal as i cant remember if it happened b4 i went at it
    Apr 2010
    333
    any one know if leaving this wire disconnected will cause any problems
