Sky InsuranceChris Nott
Thread: Airbag Light
    TDIPOWARRR
    Jul 2010
    618
    Airbag Light
    My Airbag light keeps coming on but then will go off, then come back on a minute later and so on.
    Does this sound like a loose connection somewhere?
    I've had a quick play with the sensors under the seat but it's still doing it, where abouts are the other sensors so I can give them a check?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    doesnt sound like a loose connection as when the seat puts the light on it stays on till you turn it off with vcds etc
    you need to have a code read
    Aug 2011
    Where is the sensor under the seat and how can Iidentify it?
    Hi All
    I have the same light error that comes on after (approx) 10-15 minutes of driving, and wanted to check under the seat for the sensor. I had a service and it wasn't picked up as a fault on the when the service codes were read.
    Is it hard to do/check? Should I be looking for anything specific?
    Many thanks
