EM TuningMonster Motorsport
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By swarcup
Thread: A4 TDI 130 Power loss
    Aug 2011
    Hey Guys!
    Newbie here and In need of some advice....
    Recently bought myself a 51 plate A4 1.9TDI 130 sport, full service history etc. Car was running fine until recently everytime I change gear my car loses power for about 1 or 2 secs then takes off like a rocket? This happens whether I change gear between 1500 to 2000 rpm or higher.
    Not sure if it could be the MAF sensor or maybe turbo on the way out? Any help would be appreciated... Couldnt find anything on the net relating to the problem...
    Also this doesnt happen all the time. Can happen for a day then stop for a few then happens again?!
    Daniel
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    sounds like sticky turbo vanes, they suffer a build up of soot which prevents the vanes from moving smoothly to open position hence the delay then all the boost at once. there are 2 options really to sort this, the first is to remove and send away to be cleaned and refurbed,the second is a chemical clean which has mixed results and not forced to work, however there is a growing amount of people especially in the us where they use a bbq cleaner have a read of this http://forums.tdiclub.com/showthread...=246287&page=6. i would first have a fault scan first and go from there
    Thommo likes this.
    Aug 2011
    That's great! I'll take a look at the thread and hopefully I can get this sorted!
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    does your car refuse to go above 3krpm? mine did this and it was the MAF.
    A4 B6 1.9 tdi 130. Slowly modding but don't tell the missus.
    Front ambient lighting
    Eibach sportlines.
    Audi TT Alloys.
    Aug 2011
    Still goes past the 3krpm. I had a sneaky suspision it wasnt the MAF as I had a problem with a MAF on my old MK5 Golf and it just killed the power...
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    clean the tirbo vanes firstly m8 mr muscle oven foam cleaner...... search the thread m8 and be carefull with it... skin eyes etc
    Oct 2010
    Hampshire
    294
    To test MAF, unplug it and drive the car. Uses a default set of values when disconnected. If problem goes away, then it is the MAF.
