Results 1 to 10 of 10
    Paul @ Unit9Rempas's Avatar
    Aug 2009
    north east U.K
    1,302
    Add Paul @ Unit9Rempas on Facebook Visit Paul @ Unit9Rempas's Instagram Channel
    Avant boot lock problem
    Bought the car with this problem,problems with my boot as the driver's display said the boot lid was open when it was closed, so unplugged the sensor, got rid of that for the time been, but i can only open it using the rod to the lock with the panel off, the lock doesnt even turn to open it also central locking wont open it.
    and after searching
    Seems like its a common problem, either micro switch or lock, and the rear washer leaks to cause this, Question is as this is all old info now' What am i best replacing first to solve this, full new boot lock or microswitch, any info on the costs or can i get from a breakers
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    boot lock the micro switch is in the lock
    also if you have water in there check the pipework
    Aug 2009
    north east U.K
    1,302
    im going to check the pipe work out tomorow, any pointers to the micro switch, is it where the plug plugs in, is that it ?
    bez101's Avatar
    Jul 2008
    8,430
    im pretty sure the micro switch is built in to the lock
    Aug 2009
    north east U.K
    1,302
    thanks is it the bit with the grey plug from the harness plugs into
    bez101's Avatar
    Jul 2008
    8,430
    think so yes
    Aug 2009
    north east U.K
    1,302
    thanks..............
    didnt have time to look today, engine swaps galore try to remember or take pic tomorow
    Phil-UK's Avatar
    Mar 2011
    Devon
    22
    Had to change mine recently due to the same issue. Eventually boot wouldnt close properly either and would bounce back open when trying to close it. I think it was about £26 for a complete lock assembly which does include the sensor. Easy enough to change, the trim can be a bit akward to refit by yourself but a 2nd pair of hands makes it much easier.
    Aug 2009
    north east U.K
    1,302
    where was that from for that price, you got the info there thanks
    Phil-UK's Avatar
    Mar 2011
    Devon
    22
    From TPS, I may be a few pounds out on the price though as I've bought quite a bit recently so can't remember exact figure but they are cheaper than the main dealers.
    Trade Parts Specialists
