EM TuningVolks Autos
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By quattrojames
Thread: torque setting needed front hub nut
    Mar 2008
    1,015
    anyone know what the torque setting is for a 2004 audi a4 1.8t cabriolet quattro front hub nut is please
    190 S LINE QUATTRO
    somerset
    81
    According to the good old haynes manual depends if your hub nut is 14mm thread or 16mm thread.
    M14 stage 1 115 NM (85 lbf/ft) then stage 2 angle tighten a furthur 180 degrees.
    M16 stage 1 200 NM (148 lbf/ft) then stage 2 angle tighten a furthur 180 degrees.
    These are when using a new stretch bolt, if using an old bolt you will find it hard to achieve these settings as the bolt will already be stretched. I tend to do them nice and tight using a breaker bar if i re-use the old bolt, although i strongly recommend using a new one.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,685
    If I've read it right from Elsawin:
    M14 115NM
    M16 200NM
    Plus half a turn when the wheels are back on.
    Mar 2008
    Dorset
    13,685
    Must be right then lol
    190 S LINE QUATTRO
    somerset
    81
    Yep guess so!!!!!!!!!!!!
    T0m
    Sep 2007
    Lichfield
    452
    Excuse me for acting dumb a hub nut? are you talking about the bolts that hold the wheel to the axle?
    Mar 2008
    Dorset
    13,685
    It's the bolt in the centre of the hub on the end of the drive shaft.
    T0m likes this.
