Chris NottJMB Retrofits
    Aug 2011
    Suffolk
    Help with Air conditioning fault codes from VCDS Please.
    Hi all , I'm new here today and starting off by asking for some help with my A/C. The air conditioning has been playing up for the last few weeks at first I thought it was low on gas which infact it wasn't the case. I decided to go to my local garage who had VCDS, they managed to find theses fault codes but couldn’t tell me what they mean. Hoping someone can tell me what they mean and possibly suggest what is wrong. Is there a web site which explanes the fault codes?
    1 fault found
    0132-control module for climatronic J255
    49-10 No communication-intermittent.
    2 faults found
    18043-powertrain data bus missing message from a/c controller
    P1635-008-impusible signal-intermittent
    01616-signal wire to interior monitor
    49-10- No communication-intermittent
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Ross-Tech Web Site is a good start.
    1. Scan toe faults and save a log of what they say.
    2. Clear all DTC's
    3. Re-scan and see what pops up - you may want to have a drive or leave the engine running for a while prior to doing this.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
