Volks AutosChris Nott
Results 1 to 13 of 13
    T0m
    Sep 2007
    Lichfield
    458
    Front parking sensors driving me up the wall anyone help?
    Is there anyone about with knowledge of how these are wired in....
    I thought I had a broken sensor anyhow I replaced it and it all appeared fine but that was short lived, the problem is intermittent in the sense that when I select reverse the sensors are activated and straight away the front ones start beeping telling me something is in front of me when there isn’t.
    I have tried giving them a good clean and this does nothing to resolve the problem, for instance today I selected reverse they activate and start beeping I then de select reverse and they stop now anyone who has sensors knows that they are still active and only switch off either at 10mph or by deactivating them with the button on the dash so when I de select reverse why do they stop thinking something is in front of me and go quiet....I’m thinking either it is something wrong with the switch when reverse is selected or the control module whatever controls them is faulty....any ideas anyone?
    warren_S5's Avatar
    Oct 2007
    7,164
    Sounds like a problem with a module or a cable short to me. Have you hooked it up on VAGCOM recently?
    Audi S5 3.0V6T Coupe Black Edition
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Ditto - get it on VAG-COM/VCDS for a scan. Sounds like a duff control module.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Jul 2011
    107
    Ok, I know nothing about the parking sensor system but just thought of a couple of things to look at.
    1. Do you have a reversing beeper fitted/activated?
    2. Try dissconnecting all the sensors(maybe at the module) to see if the problem persists.
    3. Can you dissconnect each individual sensor front and back 1 at a time to see if the problem goes away ever?
    2002 A4 1.9TDI Avant SE Quattro
    Revo remap
    Rotalla tyres
    T0m
    Sep 2007
    Lichfield
    458
    Guys thanks for the comments I dont have VAGCOM so cannot hook it up! Its in Audi the end of the month for the MoT so was going to ask them to check it for me.
    mememe -> The rears work fine fella, I need to know where the module is hence my first post ;-) and as for disconnecting each sensor that means removing front and rear bumpers which I havent got the time to do over the next few weeks, thats for the comments though!
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    Scanning is still the quickest way!
    T0m
    Sep 2007
    Lichfield
    458
    Thanks for that Woorlord does that control both the fronts as well?
    Im going to get it scanned the end of the month when it goes into Audi for the MoT unless anyone knows of someone near to Lichfield with VAG COM/VCDS?
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    Quote Originally Posted by T0m View Post
    Yes it does the fronts as well - there are two 12 pin connectors on the module - one for front sensors, one for rear sensors.
    T0m
    Sep 2007
    Lichfield
    458
    cheers fella will have to have a butchers and see how it goes....have never taken the interior trim out before so that will be fun....will let it go into audi and see what they say the ends of the month.
    I reckon a couple of the sensors are faulty as since ive replaced the one it seems a lot better watch this space!
    T0m
    Sep 2007
    Lichfield
    458
    Right guys car was in at Audi today for an MoT and I asked them to check this out for me, they came back and told me they are all working fine and there are no errors reporting on VCDS anyone got any ideas now apart from taking the damn thing apart!
    27,099
    Still sounds like duff module atm.
    T0m
    Sep 2007
    Lichfield
    458
    Thats what I was thinking but apart from swapping it out there is no real way of telling is there fella?
    27,099
    Nope, you need to test it with alternative modules.
