Volks AutosSky Insurance
Results 1 to 17 of 17
    Jul 2011
    107
    Knocking under load
    When I boot it in the lower gears I can hear a knocking sound from roughly under the handbrake area. It is not very loud (but definately noticeable) and knocks about 4-5 times in a second but only when accelerating. The acceleration feels smooth. A mechanic friend of mine has had it on the ramp but cannot find anything untoward.
    Any ideas please?
    2002 A4 1.9TDI Avant SE Quattro
    Revo remap
    Rotalla tyres
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    211
    are all your tyre the same make, model and size? as it is were your central diff is, if your tyre are not with in 4ish mm it will play up.
    Audi A4 1.8T quattro S Line Avant
    snowball1969's Avatar
    Mission To Mars Champion
    Oct 2010
    Corsham, Wiltshire, United Kingdom
    112
    is this a 4 wheel drive if so the prop shaft could be the culprit
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Engine mount ?
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Quote Originally Posted by snowball1969 View Post
    Going by his sig I'd say it's a 4 wheel drive
    I agree with AU01 A4, the quattro system can be very sensitive to tyre tread depths or non matching profiles. As little as 3mm difference between tread on any tyre can upset the 4 wheel drive system and put strain on it. If for what ever reason you have different profiles between tyres this can also cause problems to the quattro system.
    As regards to the prop shaft as snowball mentioned, I'm not 100% familiar with the prop shaft on the audi's, but of they are anything like BMW's then they have a big rubber donut mount between the gearbox and the prop shaft itself which will be literally the location of the knocking that you describe, so if it's split or perished it can cause a lot of movement when accelerating hard, and on the BMW's they are have a metal shield just over the prop shaft and under the floor of the car, so with movement of the prop with a knackered donut mount that can knock against each other.
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    Jul 2011
    107
    Thanks guys so far. The tyres are all the same and about the same tread depth.
    Update: The noise is worse when pulling away fast around a T junction. When doing this it becomes apparent that the noise is from the footwell are drivers side. Sorry for miss directing you.
    Revo remap
    Rotalla tyres
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Does it do it worse on left or right hand lock?
    Turkster's Avatar
    Dec 2007
    2,723
    what engine size have you got?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,265
    same here i also have this noise on take off, so far ive had 3 garages look to no avail and i have now started throwing parts at it which include all 4 arms, drop links and track rod ends both sides. Good luck
    Turkster's Avatar
    Dec 2007
    2,723
    Engine mounts can cause this as the engine will lift and clunk back down under load and the mount are in the same area as the rest of the links that you are changing.
    Feb 2011
    Ireland
    41
    I had a similar problem on my Quattro. Believe it or not it was a small stone lodged in the rubber gearbox mounting. I only got this hard knocking under acceleration and it took me a while to find the culprit. The mounting is cup shaped so stones and debris can get stuck there especially as the fibreglass cover on mine was broken and had been removed. Get the car on a lift and check the mounting carefully.
    Jul 2011
    107
    Quote Originally Posted by abyrne153 View Post
    Hey I remember seeing a stone lodged somewhere in the gearbox/surround. I'll check up on it and let you know how I get on. Thanks
    Revo remap
    Rotalla tyres
    Jul 2011
    107
    Quote Originally Posted by Turkster View Post
    Thanks for this. I have had some other issues today which I will make a new thread for and post a link. But basically, the car went into limp mode today and several fault codes were recorded. One of which was 17996 - 'Engine mount solenoid valves, open cct'
    This went away when reset. Limp mode then went away for about 5 mins then came back. I stopped, restarted the car ok, and it never came back. The only other thing of note was, it was absolutely bucketing down when I initially got the problem, then it dried out very quickly.
    Does any of this make you think more......or less that it could be the mounts?
    Revo remap
    Rotalla tyres
    Jul 2011
    107
    Worse on right lock
    Revo remap
    Rotalla tyres
    Jul 2011
    107
    1.9 TDI SE Quattro Avant 02
    Revo remap
    Rotalla tyres
    Jul 2011
    107
    Quote Originally Posted by mememe View Post
    Link to new thread
    Revo remap
    Rotalla tyres
    Jul 2011
    107
    OK I have it. It was an engine mount that was not secured correctly See here.
    Thanks to all for your help.
    Revo remap
    Rotalla tyres
