AH FabricationsChris Nott
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    2.5tdi cold starting issue
    I'm starting to have trouble when starting from cold, its fires over first time and the revs go up but then it just dies, it will carry on doing this untill I give it loads of throttle. this happens with both sets of keys.
    I have done some searching which suggests it may be the immobiliser or the coolant temp sensor (this was replaced last year). It starts fine without any throttle after its had a quick run out. seems to me like the car doesn't know its cold, what other sensors tell the ecu that the engine is cold?
    oviously getting it scanned would be ideal but any other suggestions or ideas first?
    Its had a new battery and coolant temp sensor and new cam belt/ thermostat/ water pump/ coolant recently.
    Thanks in advance
    Jim
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Glow plugs or fuel pump timing perhaps?
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    don't think so because its only just started happening and its far too warm for the glow plugs
    Jul 2007
    770
    Electrical fault?have you checked the connectors on the loom for poor contacts
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    plug it in mate, we could be here for hours guessing, my moneys on a sensor, does white smoke come out if it when it does finally fire up ?
