Volks AutosEM Tuning
Results 1 to 7 of 7
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Strange electrical problem with my front passenger door.....
    Hi guys
    Since Saturday I've had a gremlin in my front passenger door. I seem to have partially lost power to it, I have no electric window (whether it be from the drivers door or the passenger door itself) it has no central locking, so when I lock the doors from my key fob all other doors lock apart from the passenger front door, it also won't allow any of the doors to auto lock when I reach 12mph and I can't even manually lock the doors from the switch on the drivers door. I've also discovered tonight that I have no illumination on the door, I have rs4 door cards fitted which have illuminated interior door handles and they aren't lighting up as well as the electric window switch, but I do have the puddle light under the door card working as well as the red safety light on the edge of the door card which illuminate when the doors are open.
    All other doors are absolutely fine in every way apart from the front passenger door. My interior lights are also constantly on, so it must think that the door is always open but it isn't showing up on the DIS that it is open? Sometimes it shows on the DIS that the front passenger door is open when it is physically open, but other times it doesn't think show that it's open when it is.
    Any thoughts as to what this could be? Or has anyone experienced the same and found the cause? It's doing my head in so any help would be appreciated.
    Much luv,
    Az.
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,686
    Probably a damaged wire in the rubber shroud where the door hinges.
    Sent from my BlackBerry 9700 using Tapatalk
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Well I know I have a cut wire in the loom behind the rubber shroud in the drivers door because I have no sound out of my drivers door speakers at the moment, and before it got cut completely it had intermittent sound through the speaker when I opened and closed the door, so do you think it could be another wire in that loom that's damaged but on in the drivers door which would effect the passenger door? Or would it only be in the passenger wiring loom?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,911
    pull the rubber boot wires in drivers door can affect all doors
    very common
    Mar 2008
    Dorset
    13,686
    Drivers door is most common as its the most used usually, but the fault can affect any door.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    my wiring broke inside the rubber sleeve aswell few weeks ago lost all electric mirrors, windows, central locking etc easy fix took around an hour
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Cheers guys, I know I've got a snapped wire in the drivers door loom cos my speakers aren't working and I've seen the broken wire so it's no doubt another broken wire then! I'll investigate in the morning!
    Cheers!
