Results 1 to 14 of 14
    Stu!!!'s Avatar
    Feb 2011
    Cardiff
    60
    Temp gauge - possible faults ?
    Hi guys,
    My temp gauge is occasionally inconsistant, after a few mins of driving, it usually sits at 90 - however, on occasions, Ive witnessed it drop back down to 50, only for it to rise again to 90 just a few mins later.
    What is responsible for this ? Thermostat or Temp sensor etc ?
    I did use the search function, but couldnt find a definitive answer - any help would be greatly appreciated
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Temp sensor I expect, easiest place to start anyway.
    Stu!!!'s Avatar
    Feb 2011
    Cardiff
    60
    Ive just seen a part on ebay, is it a DIY jobbie or specialist job ?
    Also, is there any danger or issues driving with a dodgy sensor - may sound silly, but Id rather know either way
    Mar 2008
    Dorset
    13,856
    No real issues running with it, assuming it's not overheating and isn't the thermostat.
    What engine?
    Stu!!!'s Avatar
    Feb 2011
    Cardiff
    60
    Its a 1.8T (BEX) - and fortunately, its not overheating, it never rises above 90
    Mar 2008
    Dorset
    13,856
    There are a few threads on here about the CTS, here's a useful guide:
    :: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
    37
    Hi
    Mine did exactly the same thing - it was the thermostat. Not expensive.
    2003 A4 Avant Sport 1.9 Tdi
    Seeker_UK's Avatar
    Jul 2011
    Wellingborough
    101
    Quote Originally Posted by boddhi View Post
    HiMine did exactly the same thing - it was the thermostat. Not expensive.
    I assume Audi put the 'stat in a more sensible place in the 1.8 engine.
    2002 A4 2.5TDI Quattro Sport 180 Avant Tiptronic in metallic grey.Options (at the moment): Bose, CD Changer, Cruise Control, Heated Seats and Reverse Parking Sensors and that's about it.....
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by Seeker_UK View Post
    Yes they did, saves you a considerable amount of money!
    bowen's Avatar
    Mar 2011
    456
    where is the thermostat on a 1.8t?
    I changed my temp sensor recently, what a ***** that was. so tight no room to move!
    Oct 2010
    Hampshire
    294
    If the temp drops while there is less load on the engine, i.e. driving down a hill, then it'll be the thermostat. As they get old they get slower to close and dont always close all the way. How old is your waterpump? As the plastic impellers get old they break up and bits travel around with the water in the engine. This plastic can get stuck in you thermostat and prevent it closing properly.
    If its the temp sender then it should show up with a vag com scan.
    Apr 2011
    160
    stat is buried under the intake manifold behind the alternator. The housing is plastic with two pipes and a sensor on it. I changed the whole unit as mine was broken. Managed to do it with out taking the alternator off.
    But I eventually found out that the problem with mine was the actual temp guage it self. Must of had a dirty connection as i swapped it with the fuel guage and they both work fine now
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    id of said your thermostat is at fault not sender ??? senders usually work or they dont never seen one incorrect temps fault etc seems your thermostat is sticking open at times
    Stu!!!'s Avatar
    Feb 2011
    Cardiff
    60
    The last few times Ive used the car, short runs admittedly (3-5miles) the temp gauge hasnt budged from 50 .... which is unusual
