Badger5AH Fabrications
Results 1 to 8 of 8
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Question Needle Lift Sensor
    an interesting error code came up today when i did a random code cheek on the engine
    00542 = Needle Lift Sensor G80
    What is it and whats that all about and how easy is it to fix? cant say iv noticed the engine not running right,
    Anyone ?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Iirc it monitors fuel flow in relation to output from the injection pump and calibrates it.
    They cost about £300 + new ......
    The wire can wear through on the front of the timing cover so I'd check that first.
    Turkster's Avatar
    Dec 2007
    2,723
    is this the injector with the wire coming from it job?
    Turkster's Avatar
    Dec 2007
    2,723
    also what your saying is teh cable may be cut at that point?
    Mar 2008
    Dorset
    13,856
    Thats the injector yes, the sensor is built into it I think. I've heard that a common failure is the wire being damaged rather than the sensor itself, although this wasn't the cause for me it's worth a look.
    Turkster's Avatar
    Dec 2007
    2,723
    ok cool, will have a look at the wire, but i may be thinking the sensor as its not been changed before according to the massive service file iv got and the car has just hit the 208k miles range, so it may well be over due,
    Jul 2007
    770
    Had one go just over 100k so its just depends.Sourced one on ebay much cheaper
    Turkster's Avatar
    Dec 2007
    2,723
    got one sorted by Adams
