Results 1 to 19 of 19
    Jul 2011
    Exclamation few questions for a B7 facelift conversion on a B6 cabriolet, any help appreciated
    hi there,
    im planning on doing a b7 facelift to my b6 3.0 cabriotlet, iv checked many forums and threads and cant find the answers to the following questions, any help would be appreciated
    to my understanding i will need to change both wings, bonnet, headlights, front panel and bumper.... anything im missing?
    - will saloon b7 wings fit a b6 cabriolet or do they have to be from a b7 cabriolet?
    - will any b7 front panel fit my b6 or will it have to be a specific engine size?
    - does the bonnet have to be from a b7 cabriolet or will a saloon one fit?
    i think thats about it, i have read the b7 facelift threads and they do not have the answer to these questions, and i do not want to buy a hofele kit.
    also if any of you have any b7 parts i could use let me know as iv not started buying yet.
    A4 nut's Avatar
    wolverhampton
    352
    It all has to be b7 cab parts they bolt straight on saloon parts wont fit.
    Hope the people that took me DIE
    Jul 2011
    Quote Originally Posted by A4 nut View Post
    I was told bumper bonet front panel can be from a saloon?
    A4 nut's Avatar
    wolverhampton
    352
    easier to buy a complete front off a b7 cab that you know that fits together than to mix and match but in all honesty buy a b7 it will be cheaper to do this and what about your rear it wont match ! you thought about this?
    Jul 2011
    yeah im looking for a complete front end from a b7 cab but cant find it, and iv brought my cabby accident damaged so its wayy cheaper to facelift it then buy a b7.
    and as for the rear im sure the difference is just the 2 back lights which are not very hard to get hold of, and for the bottom i was thinking an s4 valance with quad exhaust tips.
    Jun 2010
    196
    it defo has to be cab parts saloon will not fit at all i did lots of research into b6 b7 facelifts before decideing to get an avant and do it to that also try and use oem parts as copies are a real arse to gaop and line properly
    A4 nut's Avatar
    wolverhampton
    352
    rear lights need a kufatec loom and then programming with vagcom and i only know one person that can do this and i have not seen him on this forum for a while.
    Jul 2011
    yeah am trying to stay awway from copy parts as they dont line up rite, some one just told me since my cars a 3.0 v6 i can only use the front panel from a 3.2 v6 a4.
    and im not sure about any kufatec loom, some local facelifted his a4 and dint buy none of that he just had them fitted some how but il look into that at a later stage
    Jul 2011
    26
    HelP!! Someone!! Need Advise!!!
    Hi all I'm new to this but I decided after reading on the forum to upgrade my b6 cab to the newer b7, I bought all the parts that were advised on the forum then took the brave decision to strip the whole front end off my car. My plan was to take my car to a friends garage and have him replace the timing belts ect... At the same time. Long story short eventually striped my cars front end had the belts changed then started process of rebuild using genuine parts from b7 cabs ( only part that was copy was the front slam panel) after getting my car kinda together I relised the wings fitted the bonnet fitted but the bumper didn't, although genuine part. I eventually drove my car home from the garage nearly on tears as I thought I had wrecked it... Again long story short, I was going on holiday and decided to put my car into local body shop as if anyone could get it to look right they could.... It needs all resprayed the original silver but I got a call today saying they need £450 worth of parts to get the car to come together, they say parts are bolts and fog lights + cover plates + light holders for the new lights as they are not sitting on the new slam panel..... I thought this was really expensive and need advise??????? What to do??? I know the car looks better now as he's kinda got it looking right, but says it won't be right till all parts are bought. Also HELP NEEDED with the lights themselves, I basically swapped them over and as they are plug n play I thought they would work fine, they Don't ! Needs some kind of wiring loom as all sorts of faults are flashing on dash.... HELP. final question of advise... Can I fit an HID LIGHTkit to these b7 lights??? I bought one but don't want to mess my car up any further. Please Help Advise Experts!!! thankyou!!
    A4 nut's Avatar
    wolverhampton
    352
    [QUOTE=
    and im not sure about any kufatec loom, some local facelifted his a4 and dint buy none of that he just had them fitted some how but il look into that at a later stage[/QUOTE]
    If you dont use the loom only half of the rear light will work you wont see the square on the rear light only half of it.
    Jul 2011
    26
    Thanks mate... Any more help/ advice will be appreciated. Dean!
    Jul 2011
    26
    Anymore advice on the front lights anyone??? How do you rewire them?? Thanks
    Jul 2011
    a friend told me since mines a cabriolet i wont need the kufatec wiring loom, the lights are a straight swap.
    Jul 2011
    26
    Hi, think the guys are right.... You need the loom for rear lights even if yours is a carb like mine..... But anyone know anything about the front lights, how to get them 100%, as only half working and faults on dash??? Cheers
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    Quote Originally Posted by Watchthisspace123 View Post
    you need the loom or they wont plug in at all plus you need to code them to work as they should
    iv done quite a few
    Jul 2011
    26
    Hi, are you talkin about a loom and code for my new front lights??? Not sure??? Thanks
    Jul 2011
    26
    Anyone got advise on front lights upgrade?? Do they need to be reprogrammed or something and where can I get this done? Thanks
    Jul 2011
    iv not got as far as you yet, what car front panel did you use? and what size is ur engine?
    as for the front lights i was under the impression you could cut and solder the wires to make them work.
    Jun 2010
    196
    i made my own loom went into audi and bought what they called repair wires and a connection block and trace what did what using a multimeter also took the light apart to see what pin lead to where ect then marked it all up cut out old connector and soldered mine in place
